RV.Net Open Roads Forum: Tech Issues: Propane vs Electrical use
 > Propane vs Electrical use
GeeksRUs
Sundre Alberta
Posted: 05/31/09 06:59am Link  |  Quote  |  Print  |  Notify Moderator
I lost my note that provided the formula that compared the usage of propane vs electricity on dual-powered appliances (fridge, water heater, etc). If anyone has this info, I would really appreciate the info.
Eh!
GeeksRUs
2008 Big Horn 3400RL
2008 Dodge RAM3500, Quad, Cummins, 4x4, Dually, LongBox
RV Home Base @ Coyote Creek Golf & RV Resort, Sundre Alberta
red31
Bryan
Posted: 05/31/09 07:56am Link  |  Quote  |  Print  |  Notify Moderator
http://www.propane101.com/propanevselectricity.htm
this ignores the difference in 'efficiency'.
djevans
Tennessee
Posted: 05/31/09 08:25am Link  |  Quote  |  Print  |  Notify Moderator
Maybe this site provides what you are looking for.
Don . . . near 36.171N 086.784W, TN near here
WA4ZFN
2003 Fleetwood Revolution 40C - Saturn VUE
350hp Cummins ISC
- - - P i c t u r e s - - -
I'm confused, WAIT! Maybe I'm not!
ozhoo
Cedar City, UT
Good Sam RV Club
Posted: 05/31/09 08:33am Link  |  Quote  |  Print  |  Notify Moderator
Where can I get me some of that $1/gallon propane? If that were the case propane would be more cost effective.
O
2003 F350
2003 KZ36P2
650 watts of solar feeding (2) networked Blue Sky 3024i CC, charging 660aH Lifeline AGM bank
Know before you tow- Towing Laws by State
Energy conservation is 5-10 times the value of generation. Check your appliances at EnergyStar.GOV
djevans
Tennessee
Posted: 05/31/09 08:53am Link  |  Quote  |  Print  |  Notify Moderator
-grin-
Well, it's definitely an older article!
The OP was looking for "a formula" and might "only wish" he could find $1.00 a gallon propane!
1fastdad
mo.
Good Sam RV Club
Posted: 05/31/09 09:17am Link  |  Quote  |  Print  |  Notify Moderator
It only makes a differance if you have to pay for electric. Where I stay in Forida (snowbird) propane is 3$ a gallon and electric is 16 cents a kilowatt. I have found that the best thing to do is run the fridge on electric and the water heater on gas and only turn it on when needed.
* This post was edited 07/03/09 08:00am by 1fastdad *
Clay L
Sioux Falls, South Dakota
Good Sam RV Club
Posted: 05/31/09 09:53am Link  |  Quote  |  Print  |  Notify Moderator
I wrote a program to do the calculation. It's free and you can download it HERE
The formulas used are in the help file if you want them for reference.
Clay (WA5NMR), Lee,(Wife) Codi, Brandi (Shelties) and Damncat (damn cat)
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
Dolph
Posted: 05/31/09 09:38pm Link  |  Quote  |  Print  |  Notify Moderator
Quick and easy way. Multiply electric cost X 22. If propane cost is less than that result, then it is cheaper to use propane. Maybe not exact, but is close enough for government work.
Clay L
Good Sam RV Club
Posted: 06/01/09 07:57am Link  |  Quote  |  Print  |  Notify Moderator
That's pretty close.
The unadjusted factor is 26.8. Suburban Manufacturing says furnace efficiencies range from .7 to .8 and water heaters are about .7.
Multiplying the factor by .7 gives 18.8 and by.8 gives 21.4.
22 assumes the appliances are a little more efficient than they probably are, but as you say it's close enough for a quick approximation.
GeeksRUs
Sundre Alberta
Posted: 06/02/09 06:25am Link  |  Quote  |  Print  |  Notify Moderator
Thanks to all... just the type of info I was looking for.
Eh!
