jsuutley
home
When you put camper in storage for greater than 2 weeks do you disconnect the battery because mine keep sgoing dead in about 2-3 days and i think it is from a small co2 detector under the fridge. new to forum hello everyone.
aljo17
ontario
You should disconnect the battery when you store your TT. Your smoke detector, LP gas detector etc draw a small amount of current and will drain your battery.
Old Hammer Boy
Utah
Good Sam RV Club
aljo17 wrote: You should disconnect the battery when you store your TT. Your smoke detector, LP gas detector etc draw a small amount of current and will drain your battery.
Or install a disconnect switch.
I hope you will enjoy reading my journal about my bicycle ride, camping all the way across America at www.crazyguyonabike.com/doc/dean. We also RV in our '07 Starcraft Travel Star 23QB, pulled with a good old stout Isuzu Trooper. It works
samsontdog
Sac. Ca summer, Yuma Az winter
Good Sam RV Club
I flip the disconnect switch
samsontdog
another_newfie
Ontario
Install a battery disconnect switch or disconnect the battery manually.
2009 Springdale Summerland 2600 TBL
2008 Ford F-150 Supercrew XLT 4X4
Prodigy + Equal-i-zer
4 Seasons Camping Tips & Tricks!
jay427
Ramsey, Mn
I open the battery box cover and pull out the fuse.
kraushad
Eastern Panhandle, WV
Good Sam RV Club
Hello, and welcome to the forum. While I agree that disconnecting the battery or installing a disconnect switch is a good idea, it seems to be that the battery being drained in 2-3 days isn't due to a CO2 detector. It can't possible draw that much power. Could there be another explanation for the quick drain? It seems that 2-3 days could indicate something else running, or a problem with the battery.... ??
Just a thought.
Dirk
Myself (36), my Wife(33, "The Boy"(4), & "The Girl"(negative 4 months and counting down!)
06 GMC Sierra 1500 Crew Cab, 5.3L V8, 3.42rear
05 30QBSS Trail-Cruiser, Prodigy BC, Reese Dual Cam W/D
smkettner
Good Sam RV Club
I use a disconnect switch and the 15w solar panel keeps the battery up.
Learjet
Louisiana
Good Sam RV Club
if you have run your battery dead several times I am sure it is shot and not lasting long.
2006 Nissan Titan CC with tow package added Timbrens
2006 KZ Frontier 2303P-F
Dual 6 volt GC batts
Equal-i-zer
Prodigy brake controller
Yamaha EF2600c Tri-Fuel Gen.
in the past...2001 Hurricane 30Q Chevy workhorse
Learjet
Louisiana
Good Sam RV Club
kraushad wrote: Could there be another explanation for the quick drain? It seems that 2-3 days could indicate something else running, or a problem with the battery.... ??
Just a thought.
After several trips to the dead zone, I am sure the battery is shot.
