RV.Net Open Roads Forum: Travel Trailers: Wheel chocks for wide spread axles
 > Wheel chocks for wide spread axles
Travel Trailers Related Tips
bbartschi
Riverdale, Utah
Posted: 06/03/09 11:08am Link  |  Quote  |  Print  |  Notify Moderator
We recently purchaced a 2010 Keystone Bullet 282BHS. The Bullet has wide set axles. I was wondering if anyone had any suggestions for wheel chocks that would work with the wide set axles. I am wondering if a model like the X-Chock by BAL would open wide enough for my application?
mister_d
Southeast, MI - hardly qualified to be a
Posted: 06/03/09 11:27am Link  |  Quote  |  Print  |  Notify Moderator
You could always make your own... custom(: There are a few different types around here - search for plans.
2007 Rockwood Roo 23ss
Me '77
DW '78
DD '04
DS '07
Maximus (slobbering camping buddy)
goingnorth
Petersburg, MI
I have 16" between the tires on my Keystone Passport, I use these and I just extended one side of the threaded rod 8", any hardwere store that carries threaded rod has 2" long nuts that can be used as a coupler and I used 2 jam nuts on each side to keep it locked in place. I don't have any pics of this set up yet but will soon. Someone posted a while back that they will make a clamp style set up with 4x4s, but don't know how stabil that will be at this distance between the wheels. With my ultra fab strut stabilizers I don't have any movement to stop just needed wheel chocks. This bal chock also works on top of the yellow lego style blocks, just use enough to support the chock.
To be able to use the wood 4x4 style clamp the wood would have to be 25~30"s long top and bottom, thats allot of bulk to carry around.
08 F350 FX4 CC SB 6.4L
09 Keystone Passport 290BH UF elec jack,30"scissor jacks+Eliminator Strut Stabilizer,PD9160+wizard,custom bumper hitch,added 18.5gal FW tank,Reese dualcam 800# WD,Fantastic Fan,Axle Flip,Lexan screen door covers.
My Mods.
Fraser in YYZ
East York, Canada
Posted: 06/03/09 11:29am Link  |  Quote  |  Print  |  Notify Moderator
Hope this helps.
* This post was last edited 06/03/09 11:54am by Fraser in YYZ *   View edit history
Fraser
DW
2 sons 14+17
2008 Jayco 213 Exp
2005 Dodge Durango 5.7 Hemi
Performance exhaust
Factory tow package
Prodigy brake controller
Husky WD hitch, friction anti-sway
McKesh tow mirrors
A bad day of camping is better than ANY day stuck in the city!!
Go Jays!
mister_d
Posted: 06/03/09 11:50am Link  |  Quote  |  Print  |  Notify Moderator
wow... didn't realize how far apart your axles are from each other
JHUCK
Lowry, Minnesota
Posted: 06/03/09 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
almost looks like the middle axle is missing
'05 Thor Wanderer 221SD
'00 Ford Excursion Limited V10
'78 Dodge Honey Class C
Josh, Alyssa, & Carter (1 yr)
tvman44
Southwest Louisiana
Posted: 06/03/09 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe the BAL X Chock, I just got a pair for our 5er.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
bbartschi
Riverdale, Utah
Posted: 06/03/09 01:02pm Link  |  Quote  |  Print  |  Notify Moderator
As goingnorth mentioned the distance between the tires is 16 plus inches, using a homemade block and bolt system would just be to cumbersome. It looks like the X-chock does not spread out far enough to engage the tires. I may have to use a single axle chock and just put it around one tire.
Kampfirekid
usa
Posted: 06/03/09 01:31pm Link  |  Quote  |  Print  |  Notify Moderator
I have a worse problem with my North Trail, but I am open for suggestions, too.
JJBIRISH
Butler, PA, USA
Good Sam RV Club
Posted: 06/03/09 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
I don't know but wish mine had the spread axles...
Love my mass produced, entry level, built by Lazy American Workers, Hornet
