fourfurz
Memphis
Well, it wasn't today but last week.
Checked front tires, one had a wear line from a wheel alignment problem, had to replace both front tires ($800 each), get an alignment ($300) and balance both ($50 each). The ride on the coach is quieter and seems to ride smoother, although this is purely anecdotal. If you're ever in the Memphis area and need a wheel alignment, Leland Sowell's Frame & Alignment is the place to go. They have the right equipment to do the job and spin balance tires on the coach. Great people, great service. I have nothing but positive stuff to say about those guys.
Got the yearly service done ($500) at Cummins Mid-South along with a finding that our exhaust system on the genie was missing. After a lot of searching, found the right exhaust flange on PPL for a mere $38 and got a new pipe fabricated for only $25. At least something was cheap.
Third problem, keyless entry pad on the entry to the coach malfunctioned ($200). The new one is ever so slightly bigger, so had to enlarge the opening to make it fit. Thank goodness for Dremmel.
Once on the road, everything worked as expected, so no further problems... so far.
2007 Mountain Aire 4528
2006 CRV SE
Based in Memphis area
SWM
Charleston, WV
Today I got the front tires balanced, sealed my drivers slideout, polished all wheels and chrome,and cleaned all compartments. Yes I started at 7:30 and just came inside...
JohnandCara2
Evergreen CO.
Good Sam RV Club
We Washed the exterior form top to wheel wells 40' four slides took almost 3hrs but is worth every minute. Can't wait to go camping next. I even washed the radatior out(lots of dust stuckin it) big mess on drive. HAPPY CAMPING John
Mick1152
Here
Today I stared at my RV and tried to figure out exactly how to get the new A/C onto the roof... still haven't convinced myself my plan is a good one... it involves risk, danger and damage..... I LIKE IT!
Of course... Figuring out how I'm going to get the old one off only took about 1 second of thinking and brought a big smile to my face thinking about chucking that thing off the roof :-)
Mick
1989 33' Fleetwood Southwind
2002 Saturn SL2 Toad
Rich Panganiban
Southern California, USA
Rewired the bedroom TV for a new Sony home stereo setup.
2007 Jayco Greyhawk - Kodiak 32SS
'00 Subaru Outback Wagon
John Wayne
Long Beach, Ca
Good Sam RV Club
Checked the torque on the spark plugs, re-glued the dog house cover rubber seal.
John & Carol
01 31'Sea View single slide, F53 V-10
96 Toyota 4-Runner auto 4x4 (Remco, M&G brake system)
KF6HCH
hottubkid
SCHAUMBURG,IL
Had the dash fixed and am putting it all back togeather
Second coment: Went out to start and the crack's back. They will be out Monday again.
edited 06/06/09 04:50pm by hottubkid *
hottubkid60193@yahoo.com
2004 SOUTHWIND 36E Tow 2003 CRV
Brian in Michigan
Fowlerville Mi.
Putting the front end back together after replacing the radiator. Before it's all done I need to build a new rubber dam for above the radiator
1990 GEORGIE BOY 28' 454 4BBL, TURBO 400 TRANS, Thorley Headers B&M trans cooler. Auto meter hooked to output of trans. Flowmaster mufflers
(((( 7.5mpg ))))
novaman
new jersey
Today I put on a steer safe system lets see how good it works
witzman
bowlus,mn
Good Sam RV Club
what a week! washed the 40' rv roof w/ Simple Green. caulked 2 seams w/ C10. covered roof w/ 303 Protectant. then decided to ask guy in "parts" if there is some kind of paint we can use on fiberglass roof.(theres fine cracks in fiberglass) he said "sure" Plas-t-cote. so i hit the roof w/ that. i was short 1 gal, so i'll tackle monday. then i think we're done w/ the roof. tired, mary
Dan and Mary. Rottweiler,Sarge
2010 Ultra Classic
Safari Continental AT engine 3126: Allison 3060
