bobpie
South NJ USA
NavyChaps wrote: Replaced the speakers in the sound system.
Why I ask, every now and then my speakers shut down then start working then off again. Also my floor speakers (bass) don't work at all. I don't know if it is the speakers or the radio or something else.
2001 suncrusier, 32-v, Ford V10, 4 Koni FSD, dinning slide, No leaks, 1 wife, 1 westie, life is good! 03 malibu toad sometimes, roadmaster brake pro,roadmaster Blackhawk all terrain tow bar!
SpurHntr
Northeast PA
hey bobpie,
i recently had failure of bulkhead speakers.
took them out of overhead enclosure and found all the maufacturing sawdust from them cutting the holes was PACKED into the speakers themselves...cleaned them out and they now work perfectly.
pull em out and have a looksee, if you havent already.
also, your connections may be loose, easy to see and fix as well by just popping them out to look at them.
hope thats all it is...
todd
'08 Newmar Kountry Star 3916, 400ISL Cummins
'11 Jeep Wrangler Unlimited Sahara
'07.5 LMM 2500HD Duramax Crew 8'
Blue Ox, BB, PP TPMS, BB Buggy, Ranger EV
FMCA 427040
indiana_pilot
Highland, In
PSU_RVr wrote: Modified the toilet sprayer so it could be used without having to flush the toilet at the same time.
That's something I would like to do too. How does one go about changing it? TIA
Rich Panganiban
Southern California, USA
SpurHntr wrote: Bought something for it to tow!!!
bought and driven home tonite.
dark cherry red crystal pearl '11 unlimited sahara with all the fixin's
not best pic i know but best i can do with little light and a cell phone at this hour...
now to get the baseplate installed...
...dang this is a costly "sport"! LOL
That is one beautiful Jeep!
2007 Jayco Greyhawk - Kodiak 32SS
'00 Subaru Outback Wagon
mmiille
Iowa
Had some water lines freeze up last winter so I added 1 1/2" rigid insulation below that area. Also insulated my dump valve compartment. Hope this helps this winter.
Installed a couple weeks ago an amp and Bose 301's for tailgating this fall .
edited 08/28/11 12:14pm by mmiille *
Martin & Cheryl
40 Foot 2009 Damon Tuscany
Two kids left the nest and left the wiener dog.
Full timing since Sept. 2010 so we sold the house in Feb. 2011.
pacificnw
Great Northwest
Fixed a piece of hardware (the clip that holds drawer closed) for kitchen drawer that had been shoved off original mounting position. Screws had been mounted too close to back edge and the wood gave way after (how many?) hundred closures of the drawer. Took hardware off, glued wood back together, 24 hours to set up and put everything back together.
Took all the drawers out and tightened all fittings and screws, addding several where more anchor was needed. Result was firming up the drawer slides and improved operation of the drawers.
P3TC
Glendale Springs, NC
Did the RED MAX PRO 3 treatment....looks like a brand new coach...now to clean the inside!
1998 Monaco Diplomat
mcb56
Phoenix, AZ
You get the outside, momma gets the inside.
sundancer268
Charlevoix
Just returned from a 10 day camping trip. Wish I was still there.
U. S. Navy (RETIRED) 1993
1995 Gulf Stream Scenic Cruiser 34' Diesel Pusher Cummins B5.9 12 Valve Engine, Allison MD-3060 6 Speed Transmission.
TOAD: 2005 Ford Focus Automatic Station Wagon
Road Master Sterling All-Terrain
NavyChaps
Bartlett, TN
Installed my protect-a-tow.
2003 Winnebago Adventurer 33V, Ford 6.8l V-10, Stow Master 5000 Tow Bar, Blue Ox Patriot Brake System Toad:2009 Ford Focus SE.
