RV.Net Open Roads Forum: What did you do to your Class A MH today???
 > What did you do to your Class A MH today???
Page of 466
s N s
Michigan
Posted: 09/28/11 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
Washed and waxed it. Wife is going out to finish cleaning the interior then it will be off to storage. Only until we decide where to go for the winter.
Steve & Sally
HiTee & Hudson (Our Little Poms)
Houston & Heidi (Forever In Our Hearts and Never Forgotten)
04 NEWMAR MACA 3778 W22
05 pt Cruiser Vert 5 speed
Demco baseplate with Commander Tow Bar
"Never try to outsmart your common sense"
bitster98
south texas
Posted: 09/28/11 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
Was backing up to my shop to do some work to it/found A soft spot in the drive and buried the rear wheels up to the axle!!!!! Fun fun 4 hours & one twelve pack later got her out. 38 foot Executive dont like gettin stuck!!!
mcb56
Phoenix, AZ
Posted: 09/28/11 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
What? It took you 3-1/2 hours to find someone with a 4X4 pick-um-up truck and a snatch strap to donate the beer to?
randallb
On the road
Posted: 09/28/11 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
I had jury rigged the surge tank hose on our 08 Vacationer on our last trip. The 1 1/4" hose failed because they force it over a 1 3/8" nipple on the surge tank. Monaco told me the nipple was 1 1/2" and I knew the T fitting at the engine is 1 1/4" so I had to reorder a 1 1/4" to 1 3/8" reducer so I could update to a chunk of 1 1/4 and 1 3/8" silicone hose. I now have a piece of hose that won't crack due to the heat off the regen can. I also replaced the thermostat and replaced the coolant.
Randy
NavyChaps
Bartlett, TN
Posted: 09/28/11 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
I completed an inexpensive handling fix based on the below thread:
http://www.irv2.com/forums/f23/cheap-handling-fix-72335.html
2003 Winnebago Adventurer 33V, Ford 6.8l V-10, Stow Master 5000 Tow Bar, Blue Ox Patriot Brake System Toad:2009 Ford Focus SE.
mcb56
Phoenix, AZ
Posted: 09/28/11 09:21pm Link  |  Quote  |  Print  |  Notify Moderator
Haven't tried my handling fix yet, but will soon. Please post your results.
Bounder94
Wichita, KS
Posted: 09/29/11 08:42am Link  |  Quote  |  Print  |  Notify Moderator
Installed a Marinco 30A plug in on the back of the motorhome, just inboard of the left taillight assy, routed the 10/3 wire from there, down thru the floor, forward along the inside of frame to the mid-ship services bay, thru back of bay, where it was wired to a wall-mounted j-box with a 30A RV receptacle....now, if I have a genny on the rear cargo carrier, I can plug in my RV's shore power chord, which I shortened to 18", into that 30A receptacle to run off the genny. (note: I removed my old broken Onan from the RV, since I rarely used the genny, but wanted this option of using a genny to be convenient...and by the way, when the 17 yr old Onan went out, it surged power to the ATS and fried it too, so rather than do the expensive repair on the Onan ($600-$700 parts ONLY, no labor) and replace the ATS ($150-$200), I opted to just remove them both and use that geeny bay for MORE BOONDOCKING BATTERIES!!!)
Drilled holes thru other bay walls for wiring new battery bank to an inverter in next bay, then will route wires to inverter from batteries and from inverter to service bay to another 30A receptacle to plug the 18" shore power chord into.....see, I am the "MAN"ual Transfer Switch for my 110v power sources...LOL....(the only reason for this larger inverter (2500w MSW) is for the occasional microwave use, during tailgating excursions or while boondocking...I have a smaller PSW inverter for all the entertainment equipment, inside the RV near those systems)
and replaced a faulty water pump switch in the service bay, that was near the outdoor shower assy.
Always tinkering, always fun, and we're heading out to western Kansas for a week to help nephew with the corn harvest, and we'll be boondocking out in the middle of nowhere, near the fields, moving daily, as they have 1000's of arces to harvest...can't wait to unplug from the world's news and get back to basics!!
Happy RV'ing to all
Kelly
1994 Bounder 28T with 50k
Ford 460, F-53 chassis
SpurHntr
Northeast PA
Posted: 09/29/11 08:49am Link  |  Quote  |  Print  |  Notify Moderator
fixed rear tail/brake light that came disconnected somehow...
drilled hole thru my toad's firewall for my breakaway switch wiring to get thru...headed to hardware store this after to find a grommet...
'08 Newmar Kountry Star 3916, 400ISL Cummins
'11 Jeep Wrangler Unlimited Sahara
'07.5 LMM 2500HD Duramax Crew 8'
Blue Ox, BB, PP TPMS, BB Buggy, Ranger EV
FMCA 427040
NavyChaps
Bartlett, TN
Posted: 09/29/11 09:47am Link  |  Quote  |  Print  |  Notify Moderator
It was a fairly easy mod. I have driven only about 20 or so miles afterwards, and that was all in town driving. The cornering felt a whole lot flatter and the steering seemed more responsive. I hope to get on the road over Columbus day and can give a better update then. Some of the folks on the referenced thread have put over 5000 miles on the mod and seem to be pleased.
RVRODDER
ENGLAND
Posted: 09/29/11 09:58am Link  |  Quote  |  Print  |  Notify Moderator
fitted new mesh to the roof top refer vent also repaired the refer lower vent,scraped off more old underseal and recoated with corrosion inhibiting paint,washed and leathered the lower half.After shower enjoying a cold one in the clubhouse checking out my favourite forum,not a bad day so far.
Gulfstream Sunvoyager Cummins 5.9BT DP.
Page of 466
