her&I
Ontario, Canada
sundancer268 wrote: her&I wrote: Repaired the facing around closet on bedroom slide. Do not know how it got damaged. Levelling jacks still not working.Had trouble with one not coming up on the way home and had to use manual bypass to get it up. Since then none will go down???????????
Manual By-Pass valve is probably stuck open or leaking by. I did reopen and close the valve and checked the others also
MrChuckles
Dallas
Just installed (or professional installer put in) the Winegard Trav'ler satellite antenna on our new (to us) Monaco. Hi Def rocks!
2008 Monaco Knight SKQ named Mona
mcal63775
S.E.MO.
Check Hydro fluid level?
mcal63775
S.E.MO.
Reinstalled left front leveling jack that kept leaking fluid. I Removed it two weeks ago ,sent off to manufacturer, who overhauled the jack at a very reasonable price of $120.00. It works like it should! Easy fix.
Hjudge49
St. Augustine, Fl.
Just ordered a new washing machine to replace the one that decide not to work any more. I just can't wait to remove and replace it when the new one arrives.
Yankee Clipper
Cairo, GA
Changed oil/oil filter/air filter; changed oil/oil filter/air filter/spark plugs on the generator; carb cleaner through the generator. Remove and replaced stock faucet in bath (Lowe's sale faucet). Fixed sunshade and channel on front. Remove and replace chasis battery (really dead battery). Topped off leveller hyraulic fluid resevoir (about 8 oz.). Whew.
Yankee Clipper
1997 Coachmen Catalina 330MB on F53/Ford 460efi
1991 Explorer Sport 4 down toad/Roadmaster Falcon2 with EvenBrake
TireMinder TPMS
Not overly concerned about depreciation with this rig...
her&I
Ontario, Canada
mcal63775 wrote: sundancer268 wrote: her&I wrote: Repaired the facing around closet on bedroom slide. Do not know how it got damaged. Levelling jacks still not working.Had trouble with one not coming up on the way home and had to use manual bypass to get it up. Since then none will go down???????????
Could not find the problem and took it into the shop today
xctraveler
Livingston TX
We had three day/night blinds repaired and restrung by Jackie Mosley http://rvblindco.com/ in Scottsdale. She came to the coach at 8:45 and by 10:30 she was done. They look better than the day they were new 8 years ago!
I watched closely and I am convinced that given a week I might get a couple of them done, but she had all the necessary material and tools in her car and knew exactly what she was doing with a glance at each blind. It was well worth what I paid her.
Paul
Trucking down the road in our new Phaeton 36QSH on Freightliner Chassis with a Cummins 380 pushing it. 2011 Cherry Red Jeep Wrangler Rubicon with US Gear Unified Tow Brake System. Check out my blog
FMCA 352081 SKP# 99526
RayChez
Barstow, Ca. USA
I pulled out the battery trays and washed the chassis and house batteries, checked the water level and added a small amount of distilled water on the house batteries. The two chassis batteries are sealed, so no water needed there.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar
3000 Allison Transmission
Neway Freightliner chassis
2013 Honda CR-V EX
Aventa II
FMCA member
ctpres
SAN BERNARD RIVER VALLEY, Needville , TX
Bought her a digital safe with key override, ceiling fan, Fan-tastic vent, convection heater for bedroom, drinking water filter system and 15 feet of LED lighting for cabinets
A "Retired" Mind is a Terrible Thing to Waste
Foreman Chuck USNR, USAF & USCGA
with
Headhoncho Suzie
BAR-BOB Ranch, San Barnard River Valley, Texas
2010 Damon Daybreak Classic 32'
1990 Jeep Wrangler
2011 Sea Eagle 385 FT kayak
2012 Vilano Tuono road bike
