RV.Net Open Roads Forum: What did you do to your Class A MH today???
 > What did you do to your Class A MH today???
Page of 466
revump
Las Vegas
Posted: 03/12/12 10:45pm Link  |  Quote  |  Print  |  Notify Moderator
Filled with fuel and propane and relaxing in Santa Maria, CA
Bob
dennis45
Alberta
Posted: 03/12/12 10:53pm Link  |  Quote  |  Print  |  Notify Moderator
Well, today I was going to change the air filter on my 03 Dutchstar/ 350 HP Cummins and as I was looking around, found the Exhaust Brake was hanging by a thread, big gaping holes at either end of the butterfly valve. The pipe on the outlet side of the valve had rotted away and the clamp was just hanging. Also found a crack in the manifold. Really brightened my day I gotta tell ya.
So, rather than start a major repair job in an RV Park in Texas, I went to the local parts store and bought some shim stock, heavy duty clamps and some muffler wrap. Cut the shim stock into 3" strips and wraped it around the gaping hole on the outlet side of the valve and wraped the muffler wrap around the outside of that and put 3 HD clamps over the whole thing. Counting on my repair to get me back to Alberta where I can get serious and replace most of the exhaust system. Looking forward to that. GRIN!!!!!!!!!!!
Dennis & Carol
2003 Dutchstar 40' 3 Slides, 8.3L ISC W/banks Kit 465HP,
Spartan Chassis
2010 Taurus Toad
kcstepp1992
Indiana
Posted: 03/13/12 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
Painted the air filter cover. Painted another coating on walls and cabinets. took out blinds in the bedroom. Took off bathroom door. Took off from bumper. DS started removing caulk from the roof. He filled up a walmart bag full of excessive caulking...
sundancer268
Charlevoix
Posted: 03/14/12 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
Cleaned the terminals on the battery cross connect relay and found another frame ground to remove clean and reassemble. Connected the new alternator regulator harness plug to the to the factory wires, now I need a foot or so of split loom to finish that project. Broke the screws off for the starter solenoid so I now have to remove the whole starter just to clean the corrosion from those battery cables. Wouldn't you know it, Cummins used a Metric bolt to hold the starter on that requires a 12 point 10mm socket and I do not have one. I will pick one up tomorrow along with new starter solenoid bolts and split loom. I then can finish cleaning all of my battery cable connections.
U. S. Navy (RETIRED) 1993
1995 Gulf Stream Scenic Cruiser 34' Diesel Pusher Cummins B5.9 12 Valve Engine, Allison MD-3060 6 Speed Transmission.
TOAD: 2005 Ford Focus Automatic Station Wagon
Road Master Sterling All-Terrain
Gotago2
Ocala Florida
Posted: 03/14/12 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
Changed the oil and filter on my Coachmen Mirada (F-53.) What a chore. First the drain plug was right over the front axle so had to balance the oil catch pan while I pulled the plug and as it was draining and again as I remove the filter. Yep, spilled some here and there but it cleans up. Then the biggest challenge was refilling the oil. What a job that was. I have to think of something better next time. I purchased a 5 qt. container of oil but had to pour it into a one qt container to get to the fill hole one qt at a time. You have to be a contortionist to not only see but get the oil to the hole.
Norm
2011 Itasca Sunstar 35F (35')Ford V-10, pulling 03 Nissan Frontier.
catallison777
West Columbia, South Carolina
Posted: 03/14/12 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
Washed the coach. Then Changed the oil on the generator and got everything packed up to head to Bristol, TN tomorrow morning.
2003 Damon Ultrasport 3873
Onan Quietdiesel 7500
Caterpillar 3126E
Allison Transmission 3000
Honda EU2000i
1992 Jeep Wrangler(Towed 4 Down)
mustang652
Body's in Vegas, Heart's In Texas
Posted: 03/14/12 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
Added some extentions valves to the rear outside duals so that I can more easily check and add to the pressure
Stan, Shirley & 2 Schnauzers
RVs: 2011 Vista 26P & '65 Mustang
USAF, Retired
xctraveler
Livingston TX
Posted: 03/15/12 09:45am Link  |  Quote  |  Print  |  Notify Moderator
Repaired the hinge of the bed lift.
DW lifted the foot of the bed to store the pillows as usual. this was accompanied by a cracking noise and the bed lifted canted. Turns out the nails that held the bed base to the hinge had ripped out.
Moved the mattress out to the living room, removed the gas strut on the broken side, restapled the base to the hinge and hope it will hold. Real fix will require removing the entire bed support and rebuilding the connection. Not to be done on the road this week. Maybe at my son's unless we trade the coach first.
Paul
Trucking down the road in our new Phaeton 36QSH on Freightliner Chassis with a Cummins 380 pushing it. 2011 Cherry Red Jeep Wrangler Rubicon with US Gear Unified Tow Brake System. Check out my blog
FMCA 352081 SKP# 99526
Canadian Rainbirds
Vancouver Island (Winter: Mainland Mexico)
Posted: 03/15/12 10:07am Link  |  Quote  |  Print  |  Notify Moderator
Need to totally rebuild ours too. Screws securing the strut to the slab ripped out--it's just particle board. Last year I had drilled out the screw holes and glued in wooden plugs but they ripped out too.
Like you, it will have to wait until we get home. Another on the :"To Do" list.
xctraveler
Livingston TX
Posted: 03/15/12 10:54am Link  |  Quote  |  Print  |  Notify Moderator
My usual fix for ripped out screws is far simpler, I fill the hole with hardwood toothpicks and Elmers glue. This fix has has held my driver side mirror secure for 5,000 miles.
Page of 466
