RV.Net Open Roads Forum: What did you do to your Class A MH today???
 > What did you do to your Class A MH today???
Page of 465
bigred1cav
ohio
Posted: 04/06/12 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
koda55 wrote:
Manufactured and installed the rear trac bar for my 2005 35 foot gas Georgie Boy. Took it for a 20 mile ride and the results were fantastic. Next project will be ride rites on the rear and front.
What is a rear trac bar? How did you make one?
tyoungs
Brighton, Michigan USA
Posted: 04/06/12 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
Got the Winegard Carryout up and running - 2 receivers, 1 extra input for second receiver installed by dealer (Veurinks), and activated through DISH for my RV. Went very well, especially after I hooked primary cable to Sat in coax instead of cable in coax ( ID 10 T, error).
Tom & Mary plus Snowflake the Bichon
2011 HR Endeavor 43DFT,
425 Cummins w/ Horton Fan
HRRVC #106803, FMCA #F358972
2009 Saturn Outlook toad
RV.NET Rallies attended - 6
Dale.Traveling
Newport News, VA
Posted: 04/06/12 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
Made my own windshield sun screen. $40 in material and another 40 for magnets. How’s it look?
Replaced the chassis battery. Sam's Club had them on sale for $85. Had the chassis AC recharged. Loose fitting finally let go and lost the charge. Installed new window felt on the front windows to eliminate road rattle.
* This post was edited 03/10/13 10:05am by Dale.Traveling *
2006 Hurricane 31D aka 'Moby' the Whale
FCC(SW) US Navy Retired 1980-2003
Stella my Navigator
Bogart the All American RV Dog
and
Cocoui waiting for me at the Rainbow Bridge
Dutch_12078
Great Sacandaga Lake, NY
Posted: 04/06/12 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
I took the old girl in for her annual state mandated safety inspection. She passed with flying colors, as expected.
Dutch
1995 Coachmen Catalina 322QBXL
F53 chassis, 460 V8, TST TPMS
Quadra Bigfoot EZE Levelers
mikeintn
Lenoir City TN
Posted: 04/06/12 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
Scrubbed the roof and applied a few coats of new sealer
Mike, Cindy, Chris and Spunky the Cocker Spaniel
1998 32 ft Tiffin Allegro
Ford F53 with 460 V8
Onan 5500 Watt Generator
Master Tow 80THD tow dolly
2009 Mini Cooper S Toad
koda55
Jacksonville
Posted: 04/06/12 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
bigred1cav
You might have read about the rear trac bar on here. It is put on the gas f53 chassis to help with the wandering. I was getting an aliegnment and found the bracket for the frame there. The bracket for the rear end I had manufactured at a steel manufacturing site. It was made out of 1/4 inch steel. The cross bar I found at tractor supply. It comes in different lenghts.
If you go to oemys-performance.com and click on trac bar you will see what I have done. It will also give you a diagram that you can use. I had to blow it up and then crawled under to make sure it would fit. The distances are correct if you lay down the template on the piece of steel you had cut out. Let me know if you have anymore questions.
sailor_lou
Connecticut
Posted: 04/06/12 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
Replaced the tranny filters and fluid (TranSynd).
Lou
05 Travel Supreme Envoy
artjacobs
Deep in the heart of Texas
Posted: 04/06/12 09:27pm Link  |  Quote  |  Print  |  Notify Moderator
After finally tiring of stepping over sleeping teenagers to make a pot of coffee in the morning I converted the bedroom from a double, to 2 twins & a rollaway trundel. Next week on South Padre, we'll find out if it was worth it.
sundancer268
Charlevoix
Posted: 04/07/12 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
Installed new starter and re-attached the chassis ground wires. All finished and noticed I had forgot to install the cleaned ground wire from the starter mount to the chassis frame. To tired to go back and install it today. It stinks not being able to do my own work at a better pace. I also installed new wiper blades and a new cup holder to replace the broken one on the passenger side wall. I still need to change the oil and filter and clean up the ground mounted behind the suction fuel filter. A Spartan goof in my opinion. The wiring should not be hard to access.
U. S. Navy (RETIRED) 1993
1995 Gulf Stream Scenic Cruiser 34' Diesel Pusher Cummins B5.9 12 Valve Engine, Allison MD-3060 6 Speed Transmission.
TOAD: 2005 Ford Focus Automatic Station Wagon
Road Master Sterling All-Terrain
sailor_lou
Connecticut
Posted: 04/07/12 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
The good news: I think I finally tracked down the source of the squealing noise I had believed was a serpetine belt or fan bearing problem on my CAT C-7. I verified it wasn't the belt by removing it completely and the noise was still there.
The bad news: It sounds like the turbo and there seems to be excessive play in the turbine the blades. It took me 5 hours to remove it, but on the bright side I soaked all the rusty exhaust manifold bolts/nuts with PB Blaster (that stuff is great) and they all came out with breaking. I'm sure I will be in for sticker shock when I order a new turbo on Monday, but at least my labor rate is affordable.
Lou
Revision 1
More bad news: Now that I have the turbo out, the tolerances appear to be within spec. I'm going to let the CAT dealer check it out to be sure, but this means I spent a lot of time under the MOHO and still haven't located the source of the noise. Once again, on the bright side I did learn a bunch of stuff about the operation of the turbo.
I'm leaning towards a transmission problem now and found a few internet hits related to a failing diverter valve causing noise similar to a belt squealing. Anyone have any experience with this?
Thx,
Lou
* This post was edited 04/08/12 09:44am by sailor_lou *
Page of 465
