jffhlbrt1
Bakersfield, CA
Today we had the RV washed and waxed. We had the roof cleaned and treated as well. We went to Camping World and bought new wiper blades, and generator oil and filter.
Jeff, Steve, & Nala
09 Damon Challenger 371
09 Honda Accord
Bakersfield, CA
sundancer268
Charlevoix
ordered trim parts for new stove to replace cook top wife hates. No OVEN!
U. S. Navy (RETIRED) 1993
1995 Gulf Stream Scenic Cruiser 34' Diesel Pusher Cummins B5.9 12 Valve Engine, Allison MD-3060 6 Speed Transmission.
TOAD: 2005 Ford Focus Automatic Station Wagon
Road Master Sterling All-Terrain
her&I
Ontario, Canada
Reinstalled the Sharp micro wave. If I could have found one the same size and shape I would have replaced it instead of repairing.
Mule Skinner
Pinconning, Michigan, USA
I finished replacing 8 feet of interior wall for de-lamination due to a water leak. Had a 3 foot circle of de-lamination, ended up replacing two full wall panels and insulation and repairing the rust to the metal wall studs.Panels are impossible to find so I used ceiling panels for a close match. I repaired the leak before starting on the wall.Thank God I have the tools and the skills necessary for the job. No blood or swearing several partial days and numerous trips to town. I also installed an LED TV and finished the trim work from last years laminate floor installation. The DW had surgery to replace the joint on her big toe,and can't get in the motor home, a perfect time to get some work done.
Gerry Lori and The Pace Arrow 37 With Banks Power Pack and Trans Command
MSgt USAF Ret. 1985
1988 Goldwing with 2005 Champion Trike Conversion
bigred1cav
ohio
Mule Skinner wrote: I finished replacing 8 feet of interior wall for de-lamination due to a water leak. Had a 3 foot circle of de-lamination, ended up replacing two full wall panels and insulation and repairing the rust to the metal wall studs.Panels are impossible to find so I used ceiling panels for a close match. I repaired the leak before starting on the wall.Thank God I have the tools and the skills necessary for the job. No blood or swearing several partial days and numerous trips to town. I also installed an LED TV and finished the trim work from last years laminate floor installation. The DW had surgery to replace the joint on her big toe,and can't get in the motor home, a perfect time to get some work done.
How did you do the tv? I have a PA and the tv is on the dog house?
sundancer268
Charlevoix
Worked on making wiring diagrams for chassis in AutoCAD.
sd1209
Fallbrook, Ca
Much much research and reading on this site and others and bought 6 new tires for the MH today...Decided on the Hankooks, AH11's......Cheaper than the GY's, which I had no issue with at all, but cheaper by alot......The GY's had a mgf date of mid-2005 so time to change, IMHO.....
So we'll see if going cheaper will be OK......Hankook's have good reviews and seem to be good tires......
Steve and Liz
Fallbrook, Ca
2006 Gulfstream Independence 30' 3 slides....V-10...
2010 Wrangler w/Blue Ox Towbar, Baseplate and braking system
mustang652
Body's in Vegas, Heart's In Texas
Day two of clean 'er up after a short weekend trip. Spent Thursday through Monday morning at Lakeside Resort in Pahrump, NV jus for something different to do.
Stan, Shirley & 2 Schnauzers
RVs: 2011 Vista 26P & '65 Mustang
USAF, Retired
dennis and terry
wisconsin
changed all 10 coil packs. actually quite an easy job. runs smoooth at idle; tomorrow i'll heat it up and hit the freeway.
dennis and terry
2000 damon intruder 349 (The Boo-mobile)
cats Hunter and Jazz
dog Abigail (newly adopted from humane society)
1995 Saturn wagon toad
mscamping
any place, USA
Installed a CB antenna,ran some wiring for a 120 volt outlet and installed it, then put more insulation in the header cabinets above the dash..Mike M..
2003 Holiday Rambler Neptune 36 PBD - ISB 300 Cummins- Allison MH2000 5 speed
2009 HHR w/Blue Ox Aventa II & SMI Stay-n-Play Duo
FMCA 331658 HRRVC 105155 Chapter - 57- Good Sam Life Member - Coach Net - 3/4 timers
Mike & Sharon
