RV.Net Open Roads Forum: What did you do to your Class A MH today???
 > What did you do to your Class A MH today???
Page of 467
toomoxy
Canada
Posted: 06/28/12 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
Ramair wrote:
installed new oxygeniated shower head .
Do you find that the head does give more pressure than your old one ?
I have that burnised bronze look so hate to change it out for silver...but... I would like more pressure in the shower..
thanks in advance for review of the shower head.
Jim Norman
NJ
Posted: 06/29/12 10:22am Link  |  Quote  |  Print  |  Notify Moderator
Installed the ScanGuage. (Easy) Programed the ScanGuage, not so easy, damned fine print, had to enlarge and reprint so I could tell the letters and numbers apart. Now reads Transmission Fluid Temp, and Cylinder Head Temps. Will see how it goes. I like the LOP and Average MPG up as they should help me tune my driving for better economy.
As for the Shower head mentioned in the previous post. I bought one and used it in the rig for one short trip last month. Liked it so much I took it out and put it on the shower at home. I'll buy a second one this weekend for the rig. It gives great pressure and seems to use less water as well as allowing for good temperature maintenance, it doesn't shut off all the way so you don't get eh cold or hot blast that other shower heads give.
2009 Itasca Sunova 35J
2008 Jeep Liberty (aka FireToad)
sundancer268
Charlevoix
Posted: 07/04/12 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
Removed the cook-top and started modifying the cabinet so I can install a real Stove/Oven for the head cook.
U. S. Navy (RETIRED) 1993
1995 Gulf Stream Scenic Cruiser 34' Diesel Pusher Cummins B5.9 12 Valve Engine, Allison MD-3060 6 Speed Transmission.
TOAD: 2005 Ford Focus Automatic Station Wagon
Road Master Sterling All-Terrain
The Beave
Georgetown TX USA
Posted: 07/05/12 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
After finishing the rebuild of my battery tray and re installing the batteries I found there was a dead cell in one of the 5 year old Trojan T105 house batteries.
By the way, I used a large 1/2" thick polyethylene cutting tray from Sams club for the bottom of the battery tray.
Today I purchased 4 Interstate GC2 UTL's from Costco for $79+ and loaded them in the battery tray. Tomorrow AM while it's cool I'll hook up the cables. Hopefully this long battery process is over!
The Beave
30' 1997 Beaver Monterey
(The shortest DP we could find)
2005 Honda CR-V
Remco surge brake
georgetown stan
vevay
Posted: 07/05/12 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
I spent the day waxing it as I do that twice a year . This way when I go to our South Carolina spot I dont worry about salt air I love looking at this 35ft monster and still piddleing aroud changeing this and fixing that.
kcstepp1992
Indiana
Posted: 07/05/12 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
Any Photos? I may have to do this and am interested in how you put the cutting tray in there. Sounds like a great idea.
I painted bathroom wall and put up trim in bathroom.
I also put up reflectix in the front windows.
Super Guy 78
Augusta, GA
Posted: 07/06/12 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
Will , I have 37 foot 98 Newmar Mountain Aire, I decided to remove the pull out bed and make the whole area living. Removed day bed, move the dining table to the front of slide and was able to put in the extra leaf by turing the table, make more table for two to set at. Remove the chair next to the door and replace with a table, move chair into the slide and then when to lazy boy and bought another rocker and a small oak table between the two chair, give us more room and it is not a bedroom/living, all living. Steam clean carpet, new TV, with the new Jack Ant. new electric Ref. no more gas Ref. new 8KW genset and installed the Bank on my 5.9 Diesel engine and fixed the KDP, new tires and put Red Max #3 on out side,(6 coats). Now will save up some money so we can use it,!!!!!!!!
daverich
Swan Lake National Wildlife Refuge, Sumner, MO
Posted: 07/09/12 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
I replaced my smoke alarm with a new Kidde PI9010 Battery-Operated Dual Ioniz........ion and Photoelectric Sensor Smoke Alarm
and my carbon monoxide detector with Kidde KN-COSM-B Battery-Operated Combina........oxide and Smoke Alarm with Talking Alarm.
RayChez
Barstow, Ca. USA
Posted: 07/09/12 10:38pm Link  |  Quote  |  Print  |  Notify Moderator
Just got back from spending sixteen cool days up in the mountains at Pine Cove, Calif. I had a slight problem with my chassis batteries and had to use the jump switch to start the coach with the house batteries. So today I went and purchased two 31 MHD Commercial batteries from Napa and installed them on the coach. Only took me about fifteen minutes to install the new batteries. The Interstate workaholic that it had lasted six years. So I guess that is not too bad for a chassis battery. Hope these other batteries from Napa last just as long.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar
3000 Allison Transmission
Neway Freightliner chassis
2013 Honda CR-V EX
Aventa II
FMCA member
Scott & Jill
Posted: 07/10/12 11:14am Link  |  Quote  |  Print  |  Notify Moderator
Do you still have a place to sleep and how do you keep the frig cold while you are driving run the generator all the time? Just asking I would like to see some photos on your setup sounds interesting.
Life is too short; enjoy it the best way possible
Page of 467
