sundancer268
Charlevoix
Ordered new Delco Clone 28SI 180 Amp Alternator to replace the 22SI one wire which I hate. Hopefully it will be here next week. Less than two weeks until our vacation, getting antsier the closer the time comes.
U. S. Navy (RETIRED) 1993
1995 Gulf Stream Scenic Cruiser 34' Diesel Pusher Cummins B5.9 12 Valve Engine, Allison MD-3060 6 Speed Transmission.
TOAD: 2005 Ford Focus Automatic Station Wagon
Road Master Sterling All-Terrain
Bigdog
silverdale wa.
Drove from Bremerton to Portland yesterday for my aunt's 90th birthday on Saturday.Wow,great trip and no problems.
Got up this AM,made coffee and went outside to pull the window awnings down and the door awning bracket pulled out of the wall.Fixed that.Then I went to put the main awning down and discovered that I was two inches from extending it because of a tree. Started it up,pulled the jacks and moved two feet just to be sure.Put the awning down and turned around and walked into the rear arm.ooppss.
Hooked up the drain hose and discovered that it goes uphill.Durn.
Went in to wash my hands and found out that the kitchen faucet sprayer had stuck in the on position after th DW had washed her hair.
Sat around outside reading a book and relaxing till the temp got up to 90 and now I'm inside in the 64 temp from the A/C's which are working well.
So,now I guess it's Miller time.Well actually a 22 ouncer of Silver City Fat Woody Scotch Ale at 9.5%.Now I won't really care if anything else goes wrong.
GO COUGARS
2001 Tradewinds 7390 LTC
330 Cat Turbo Freightliner Chassis
2011 Jeep Liberty(toad)
'88 Mustang 5 Spd 5.0L GT convertible (not Toad)
kpconnell
Seattle, WA
Got a stereo installed. Finally!
RayChez
Barstow, Ca. USA
I have been waxing my coach with VIP Swirl Away. I work on it for about two hours everyday after the sun goes down and it cools down some. No big rush taking my time and in two days working on it for two hours a day I have about three quarters of the coach done. WOW! this stuff really makes it look like a brand new coach. The paint job with the clear coat you can see yourself like a mirror. I will finish the job tomorrow. I want to get this done before we take off on an Alaskan cruise. Protect the paint job because this has been a very good coach and it seems like it will serve us a long time.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar
3000 Allison Transmission
Neway Freightliner chassis
2013 Honda CR-V EX
Aventa II
FMCA member
Greyghost
On The Road To Somewhere
Installed a Verizon antenna for my mifi access port. Didn't get any more bars, but so far there haven't been any dropped connections. Even with a major storm that rolled through here last night (Northern Minnesota).
Pat & Roger Fisher
2004 Mountain Aire 3501
2007 Honda CRV EX-L 4WD,
Jewel and Clifford Bouvier Des Flandres
zmotorsports
Utah
Finally got around to investigating my ground issue for my dash gauges. I only picked the hottest day of the year to work right behind that huge windshield. I pulled the dash apart and found a ground connection that I was getting about a .6 volt drop across from the main ground buss.
Whenever I would turn my headlights on or windshield wipers and the lights would come on my gauges would all change due to the added resistance. Now everything is working perfectly.
I also was informed on our last trip that my right side brake lights were not as bright as the left side so I tore into that and found another grounding problem back there. Corrosion was causing about a volt voltage drop to the right light bank. I cleaned all of the connections and we're good to go there as well.
I did a good semi-annual inspection of my hitch bolts and welds prior to towing our trailer this next week.
Mike.
2003 Monaco Dynasty/ 26' Haulmark Edge trailer
2011 Jeep Unlimited Rubicon
Raymon
Phoenixville, PA
Got it ready to take 3 grandchildren camping for 6 days this coming week. Looking forward to all the fun and the memories we will be making. I don't let the grandchildren know, but I have as much fun as they do.
Ray
sundancer268
Charlevoix
Installed replacement Battery Cross Connect Relay and TST Tire Pressure Sensors on the Motor Home. Will do the car tomorrow.
psmoore
Illinois
Took our first trip in the class a today! Great fun, although it stormed for awhile. No water leaks that we can see.
Paul and Susan - 4 kids
2001 Winnebago Brave 35C
purplekeenah
greensburg, pa
I tied to find an adjustment for the curbside front slide. At times it gets really snug to the front end of the opening, right now it is rubbing the the top right corner. Anyone know how to center the slide in the opening?
2007 Newmar Ventana 3936
330 Cummins
2013 Chevy Equinox
