RV.Net Open Roads Forum: What did you do to your Class A MH today???
 > What did you do to your Class A MH today???
Page of 465
kcstepp1992
Indiana
Posted: 05/16/12 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
Applied Liquid Rubber Roofing. 4 hours 42 minutes from mixing to sitting at home. Ill post some photos once I can get up there and take some after pics. Used more than I thought I would and will probably have to go get a gallon to finish off the front corner.
Also even on a breezy day.....holy cow did the fumes make me woozy. I even had a dust mask on for part of it. Also any warmer and it would have dried entirely too fast. It was setting up really well and I only let it sit with the catalyst for about 30 minutes while getting the ac vent off and such. Glad I didnt wait longer.
toomoxy
Canada
Posted: 05/20/12 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
Found a great RV guy to do all my little fix it projects !!
Added Screen door bars
added stove top cover
dewinterized
put EZ track on walls of garage (so I can stack cages for dog show)
fixed the broken drawer under the couch (bought RV used)
Future Considerations:
automatic fan for washroom (have a crank I can barely reach)
maybe motion detection lights for outside (?)
AND... when i have company I would love to have a private area to sleep...
Does ANYONE know where i can find this "studio loft bed" as I want it. or some simular idea..
kcstepp1992
Indiana
Posted: 05/23/12 02:12pm Link  |  Quote  |  Print  |  Notify Moderator
Put on a new step. Had to drill new holes to line it up with the brace so it flushed up.
Put up more walling in the bathroom. Going to have to add some bracing to the flooring in the bathroom. Anyone know why they have a lifted area in the bathroom and nothing underneath that for support. Seems to me a toilet and a person on that piece of wood warrant bracing. Guess thats another day project.
Painted some more doors. Hooked all the batteries up and everything ran great. Loaded the generator with the AC and it felt good. Starting to see the end of the road finally.
jassrnj
Bath, PA
Posted: 05/23/12 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
Installed heat reflecting material under the dog house.
Installed new towel bars.
Mounted a GPS and a Scanguage on the dashboard with velcro.
Stacked bricks under the shower floor so it won't bow.
Installed a new 36" TV and a new DVD Player.
Installed a new clock that also gives me the outside temp.
Tested out all systems for our 3 week vacation coming up this weekend.
Now I need a vacation.
bigred1cav
ohio
Posted: 05/23/12 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
Took it to repair shop. Very bad miss and gen don't gen. Runs but don't gen.
koda55
Jacksonville
Posted: 05/23/12 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
Put the ride rite air spring on the rear of our 2005 georgie boy landau. Inflated to 50 psi. Now to find the real pressure needed. Front is my next project.
Canadian Rainbirds
Vancouver Island (Winter: Mainland Mexico)
Posted: 05/23/12 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
Went inside to see what I have to do for the FMCA Vancouver Islanders Rally this weekend and found a new Sirius Radio still in the box lying on the dash. I suspect that DW will want me to install it!
Zany
Sanibel Island, Florida
Posted: 05/24/12 10:14am Link  |  Quote  |  Print  |  Notify Moderator
Changed out the plastic coolant recovery tanks on both the Cummins ISL 400 and the Onan Genset My coach is a 2004 Safari (by Monico) - - both tanks showed some cracking near the corners and the tank on the genset was 'wet' on the bottom.
These tanks are very important inspection items, for any unit more than about 7 years old and one that most folks and even technicians don't think about. Having your coolant blow out while you're on the road will shut you down - usually at a very inconvenient time
Also had the oil and all filters replaced, then I replaced all 6 batteries (house were 5 yrs, chassis were over 8 years but still starting the unit) Cleaned out the compartment too.
Changed both windshield wipers - took awhile to find parts as they are screw on vs. clip on type - - finally at NAPA - the were almost $30 each even after a AAA discount but the previous ones lasted over 8 years.
'04 Safari Zanzibar, 40', 3 slides, 400 Cummins ISL
Honda Odyssey toad, 2-15 yr old Balinese cats
first coach
baileyjmad
Central Florida
Posted: 05/24/12 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
Took the 2012 Thor Hurricane and the soon to be toad (2012 Chevy Equinox)in to be set up for toad towing. Getting a Blue Ox baseplate and Alpha towbar installed and the US Gear Unified Tow Brake System. Pricey but expecting (hoping) for an easy tow/disconnect experience on our trips.
Yellowboat.
Auburn, WA
Posted: 05/24/12 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
Re-strung the day/night shade in the bed room.
Replaced the cold air return vent cover.
2005 Winnebago Sightseer on a 2006 Ford F53 Chassis
Miata on a Featherlite trailer
Mack our Pom
JD & Kathy
Page of 465
