RV.Net Open Roads Forum: Truck Campers: black streaks
 > black streaks
Truck Campers Related Tips
MTW1
north carolina
Posted: 06/04/09 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
What do you use to remove the dreadful black streaks from you aluminum camper skin ??? o yah.....effectivly
swebber
Brunswick , MD
Posted: 06/04/09 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
On our 1st TT I used cleaner wax or white automotive polishing cream. I do the same on our Haul-Mark enclosed trailer.
Steve & Tracy Webber
'07 F250 6.0PSD LariatFX4 LB,AirLift,Edge,IFW BedSlide
'09 Jayco Eagle 324BHDS "CramalotInn III",Reese DCHP, Atwood 3500, BAL Deluxe Chocks, Weber Baby Q & Q200, Champion 4000 gennie
Our Camping Pic's
just_dave
Bay City, MI
Posted: 06/05/09 05:58am Link  |  Quote  |  Print  |  Notify Moderator
Simple Green. Dilution depending on how bad the streaks are. Sometimes 50-50, sometimes 100% if they are real bad. Find the right mix where you don't use too much but get the work done. Also helps to let it soak for a bit before scrubbing. I find it works better than Awesome. - Dave
2001 2500HD 6.0L 4.10 4x4
1999 Jayco Eagle 285BHS 5er Thank you Lord!
Draw-Tite 16K with Kwik-Slide
Prodigy
Bilsteins (on the truck)
Monroes (on the 5er)
Roady2 XM Radio
Perception Swifty 9.5 Kayaks
Pelican Break Kayak
BelleisleNB
Kiersteadville New Brunswick, Canada
Good Sam RV Club
Posted: 06/05/09 06:26am Link  |  Quote  |  Print  |  Notify Moderator
We use Orange Fantastic. Just spray on and wipe off.
RevLeonidas
Oregon
Posted: 06/05/09 06:53am Link  |  Quote  |  Print  |  Notify Moderator
...elbow grease is the only thing that has ever worked for me; wash it, scrub it, and then I wax it. If you can get lucky like Just_Dave maybe simple green will work for you; however, I wasn't so lucky, and simple green was but a disappointment.
Rheevs
Minnesota
Posted: 06/05/09 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
The easiest way is to prevent them. I clip cloths pins to the gutter drains to keep the water from draining down the side of the RV. If you do not have gutter drains you can get them at any RV supply. keeping the roof clean as possible also helps.
Life Is A Journey Not A Destination
Good Luck !
Vicki and Ed
2009 Cedar Creek 34 RSLA
Trail Air Hitch Coupler & Equa-Flex Flexible Equalizer
2008 GMC Sierra 2500HD, Ext Cab, D/A, 4x4
"Ride-Rite" Air Bags & SuperGlide 18K
Wheelholder
jacksonville, fl
Good Sam RV Club
Posted: 06/05/09 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
A solution for the black streaks is a wet used dryer sheet. Get it damp and wipe the black streaks right off. Saw this on another rv site. Works for me
2008 Silverado crew cab Duramax/Allison
2008 Lance 805
dmax lover
Portland,Oregon, USA
Posted: 06/06/09 08:03am Link  |  Quote  |  Print  |  Notify Moderator
I used Camco Black Streak Remover long ago on an old winnebego - from memory, seemed to well, but didn't get them off completely (it was really bad at the start...)
I have also used s100 total cycle cleaner on occasion - but it is really, really expensive (but worth every penny)... Honda repackages s100 and sells it as hondabrite.
S100 Total Cycle Cleaner (expensive)
Pro Honda Chemicals - Hondabrite (s-100 repackaged by honda)
S-100 is very, very expensive but works very well - I use it to clean my motorcycles and will occasionally use it on other items to take care of road film, stains in the finish, etc. Only use on a finish if it is cool to the touch - I usually wash the vehicles at dusk.
jeff
2005 Chevrolet Duramax 3500 SRW Crewcab Longbed (KYB Monomax Shocks, Michelins,Pacbrake Airbags,Hellwig Rear Swaybar)
2006 Northern Lite 9.6 Classic (Torklifts & fastguns)
MTW1
north carolina
Posted: 06/07/09 07:33am Link  |  Quote  |  Print  |  Notify Moderator
thanks ! i like this idea... not corrosive to the aluminum, but effective
 > black streaks
