RV.Net Open Roads Forum: Fifth-Wheels: Gallley drain valve on a 2004 Montana 2980RL
 > Gallley drain valve on a 2004 Montana 2980RL
KOUNTRY TRAVELER
Hot Springs Village, Ar.
Posted: 06/06/09 05:26pm Link  |  Print  |  Notify Moderator
Just purchased this fifth wheel and thought the kitchen drain was clogged because it backed up into the sink. The monitor for the tanks shows the grey water empty after dumping but the galley still shows full. I'm assuming there is a separate holding tank for the galley but how do you empty it? Other fifth wheelers have told me that they should all be together.
When I look at the manual for this model it only reads that there maybe 4 tanks but does not go into detail on were the drain valves are. The grey and black tank valves are side by side in the front of the trailer but all I can see from the back of the trailer were the galley tank has to be is a black drain pipe running to the dump outlet.
Need your help in Arkansas.
Thanks
cummins2014
Utah
Posted: 06/06/09 05:37pm Link  |  Print  |  Notify Moderator
Thanks
There is a third drain valve on the left side between and slightly above the tires
rhochnadel
Arizona
Posted: 06/07/09 08:51am Link  |  Print  |  Notify Moderator
Our galley drain valve is in the sewer hose storage compartment, you have to take the hose out first.
'05 Keystone Challenger TPK
'01 Chev 2500HD Duramax/Allison
Corgi "Pippin" & cat "Sundance"">
Mile High
CO
Posted: 06/07/09 09:24am Link  |  Print  |  Notify Moderator
yeppers - on the frame between the wheels. Catches a lot of folks off gaurd on the Montana.
2013 Winnebago Itasca Meridian 42E
2013 Jeep Wrangler Unlimited Sahara Towed
et2
MI.
Posted: 06/06/09 06:02pm Link  |  Print  |  Notify Moderator
Thanks
Yup.Found this out on our new Montana as well. Driver side,probably under the slide behind and between the tires. Great place to put one !! I found our when I was lubing the slides.
LadyRVer
Posted: 06/06/09 07:31pm Link  |  Print  |  Notify Moderator
My 2003 Montana had the galley drain behind the street side rear tire. My 2008
Montana had the galley drain in front of the street side front tire.
Mile High
CO
Posted: 06/08/09 07:26am Link  |  Print  |  Notify Moderator
Better than on the roof I guess[emoticon]
KOUNTRY TRAVELER
Posted: 06/07/09 07:07pm Link  |  Print  |  Notify Moderator
Just want to say thank you to all of you who responded with the correct information.
I thought I had to be the dumbest person in the world but now the #1 in that catergory is the designer who came up with that location.
Anyway the problem has been resolved and a thank you to all of you who replied.
The Kountry Traveler
Hot Springs Village,Ar.
noman'sland
Boise City OK
Posted: 06/07/09 03:29pm Link  |  Print  |  Notify Moderator
On our 2000 Montana it's between the tires, quite a crawl to get to it, so I had another drain installed in the line just above the final dump valve. It's a lot easier to get too. Sometimes I wonder if any of the designers have ever used one of the trailers that they build, I can't believe the lack of common sense in putting the dump valve in such an akward place. Dumb, dumb,dumb.
Vernon & Martha
02 F 250 PSD 7.3 4x4
00 Montana 3280rl
timandsusan
San Antonio, Texas
Posted: 06/07/09 09:56am Link  |  Print  |  Notify Moderator
This caught me off guard on our Montana as a rookie RVer in 2006. The usual location is near the tires on the driver side.
