RV.Net Open Roads Forum: Tech Issues: Stubborn air conditioner
 > Stubborn air conditioner
Tech Issues Related Tips
jimjr
Ohio
Good Sam RV Club
Posted: 06/09/09 05:31am Link  |  Quote  |  Print  |  Notify Moderator
We can only use our TT 3 summer months of the year and then it is stored in an unelectrified barn about 30 miles away from home.
The problem we have happens when we bring it home to clean it and get ready to go. The AC fan will not turn and all we get is the hum of the motor trying to start. When this first happened a year ago, our dealer told us that the fan shaft rusts in place and that all that's needed is for me to rotate the fan to get it broke loose. This done, it runs like new. The dealer said there is no way to lubricate the shaft since it's a sealed unit..........
The questions I have are:
1. Are we the only ones this happens to?
2. Are there any solutions other than poking a stick in the vent holes to rotate the fan?
We of course could remove the AC cover but at this old age that ain't gonna happen.
Any solutions .. short of replacing the motor????? Thanks in advance for your help.
Jim ----- SampsonAFBVet
Joyce --- Teacher
Jess our Basenji
2004 Sunline T-2499
stageline
Tulsa Ok
Good Sam RV Club
Posted: 06/09/09 05:43am Link  |  Quote  |  Print  |  Notify Moderator
It sounds to me like it could be a bad starting capisator.
Robert, Brenda & our dog Brandy
2002 D/A CC LB 3500
2000 5er Savana 35.5' W/3 slides,
360 Watt Solar Panels, 2000 Watt Inverter, 4.5 KW Onan Generator
toad Jeep Grand Cherokee
troll3193
SouthWest, MI USA
Posted: 06/09/09 06:10am Link  |  Quote  |  Print  |  Notify Moderator
on our current TT it has always done this... happens when we first start it for the year...
I have to remove the cover so I can see the fan. turn on the fan, then use a stick to spin it to get it started. I let it run for several hours, then it is fine for the rest of the camping season...
Bryan
2006 RAM 3500 MegaCab w/Cummins Turbo Diesel
Mopar Exhaust Brake
2004 Dutchemen 31BK
SteveB
Rhode Island
Good Sam RV Club
Posted: 06/09/09 06:12am Link  |  Quote  |  Print  |  Notify Moderator
Is it a Dometic AC unit?
There was a recent recall of blower motors with this problem.
'01 Dodge Ram 3500 CTD HO 6sp, Reese 15K Pro w/ Kwik Slide, Prodigy
'04 Jayco Jayflight 28.5RKS
tvman44
Southwest Louisiana
Posted: 06/09/09 06:27am Link  |  Quote  |  Print  |  Notify Moderator
A new motor will probably do the same thing.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
bigrigger
Ontario,Canada
Posted: 06/17/09 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
i/m haveing the same problem blower motor is siezed how would i find out if mine is recalled also?
98' dodge ram 2500 diesel auto 4x4 05' dutchmen 27' 5th wheel connected via a dsp hitch
mockybird
Mocksville,NC
Good Sam RV Club
Posted: 06/17/09 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
Have had this problem before and some WD40 and a spin or 2 of the blade from the roof will send it running. NOTE...do not have it turned ON when you turn it. Spin it with power OFF. I doubt you need a new motor or anything more than this. Inactivity is the problem usually
Gary
sljkansas
Miami Co. Kansas
Posted: 06/17/09 03:08pm Link  |  Quote  |  Print  |  Notify Moderator
Go to Radio Shack and get some "phonolube" it's use to grease old record players but is also used for motor shaft. I had the same problem you did and removed the cover, spun the blade, cleaned to dirt off around the housing by hand then by using the tube pushed grease around the shaft.
Worked for 3 more years and was still working when I traded it in.
I also use it to lube shafts on all types of motors.
CAUTION, do not use motor oil, some of the aditives will just gum up the motor shaft quickly.
Steve & Linda
Son married (1 DIL, 3 granddaughters 1 grandson)
Daughter in College
Miami CO. Kansas
2004 F350 CC dually 8ft bed 6.0 PSD
2009 Bighorn 3670RL
B&W under bed hitch with 18k companion hitch
smkettner
Good Sam RV Club
Posted: 06/17/09 03:15pm Link  |  Quote  |  Print  |  Notify Moderator
Sealed unit that rusts in place? Oxymoron?
Either the seal is bad or you can lube it. JMHO
I would disassemble a bit and see if I could get a drop of oil on that shaft.
jetcare
Mission, TX
Posted: 06/17/09 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
Sometimes I notice that the motor rotor gets rust on it and you get binding between the rotor and the stator. Removing the AC cover and turning the fan blade by hand knocks the rust loose and you are good to go. Sometimes, it is very rusty and you have the rock the fan blades back and forth gently.
Matt
A-1 Mobile RV Services
