RV.Net Open Roads Forum: I Did Some Tire Shopping - 245/70R 19.5
 > I Did Some Tire Shopping - 245/70R 19.5
YoBubba
Posted: 06/10/09 08:20am Link  |  Print  |  Notify Moderator
I did some tire shopping this week I thought I would share the price quotes I received.
Goodyear Dealer
Goodyear G670RV
245/70R 19.5 Load Range G $325 ea. + M, B, I = $2,390.28
Toyo M143
245/70R 19.5 Load Range G $247.99 ea. + M, B, I = $1,916.14
Independent Dealers
Michelin XZE
245/70R 19.5 Load Range F $ $303.47 + M, B, I = $2,012.75
Bridgestone R250
(1) 245/70R 19.5 Load Range F $283.72 ea. + M, B, I = $1,887.14
(2) 245/70R 19.5 Load Range G $321.10 ea. + M, B, I = $2,318.79
Firestone FS560
245/70R 19.5 Load Range G $257.76 ea. + M, B, I = $1,624.56
Kumho KH6932
245/70R 19.5 Load Range G $267.95 ea. + M, B, I = $1,965.11
All but one dealer said they would balance the tires except one, who recommended balancing beads called CounterAct.
I have a Ford chassis MH, that rides and handles fairly well, so I at this point, I am inclined to go with the G670's in hopes I won't screw up the ride and handling. With the announced $50 per tire rebate they a little more price competitive with the others.
I am also looking hard at both the Bridgestone R250's and the Toyo's. Both look like very good tires. Does anyone have any experience with either tire?
I have load range F G670's on the coach now, and Winnebago spec's running at 80 PSI. Can the load range G 670's be run at 80 PSI ? I know, weight the coach, and I will, but feel the need to ask the question BEFORE I agree to move from an F to a G range tire.
* This post was edited 06/10/09 07:44pm by YoBubba *
Bearnkat
Fort Worth, Texas
Posted: 06/10/09 08:25am Link  |  Print  |  Notify Moderator
Hummm....seems like this post is in the wrong area. I'm sure a moderator will move it to the proper area. [emoticon]
Chuck & Terry
2005 Pilgrim 281RB-S
2006 Ford F250 Lariat CC 4x2 PSD
My Lap-Band Journey!
Chuck and Terry's Pilgrim Adventures
C & T's Photos
Lone Star Dutch Oven Society
bldrbuck
one or the other
Posted: 06/10/09 09:27am Link  |  Print  |  Notify Moderator
You are going to g rated due to a discount? Check the rating on your wheels and the book for the weight on gs. You may be able to increase the pressure if necessary.
cpmath
New York
Posted: 06/10/09 11:19am Link  |  Print  |  Notify Moderator
You should be using F not G load range.
Jim@HiTek
Gresham, OR, USA
Posted: 06/10/09 11:24am Link  |  Print  |  Notify Moderator
Not sure but think if you go from F to G your PSI rating goes up...
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Winnebago Journey, '02
Cat 330HP Diesel, 36.5', two slides.
LVJ58
Las Vegas, Nevada
Posted: 06/10/09 11:40am Link  |  Print  |  Notify Moderator
I looked hard at both the Bridgestone R250's and the Toyo's Booth look like very good tires. Does anyone have any experience with either tire?
YoBubba, we have the Bridgestone R250F series load range "G" on our coach (F53 Chassis) and highly satisfied with them. Must admit I'm biased toward the Bridgestones. However I've heard good reports on Toyo's as well.
Don't think you'll go wrong with either brand.
Jim & Sherry Seward
Las Vegas, NV
2000 Residency 3790 V-10 w/tags & Banks System
2003 Suzuki XL/7 toad
tahiti16
Camarillo, CA
Posted: 06/10/09 12:00pm Link  |  Print  |  Notify Moderator
The G rated will have a higher load rating and possibly a harder ride!
Ray, Cheryl & of course Miss Molly the four-legged child
2006 Dolphin 36' F53 V10 5 speed auto 2 slides 7.5 KW genset
traindriver
illinois
Posted: 06/10/09 12:57pm Link  |  Print  |  Notify Moderator
I justy put G rated on my moho and they carry a max 110 pds of air. They are Continental 225/70r/19.5. They are balanced, knee deep in rubber, ride very well, and if you desire, they are regroovable. Just FYI.
FrankReno
Reno, NV
Posted: 06/10/09 01:31pm Link  |  Print  |  Notify Moderator
Why?
Frank & Marion
2004 Southwind 36B
Workhorse W22
Little Green Jeep Toad
Driver Jake The Wonder Dog
Copilot Chip the Pup
wshrman
Orange, Ca.
Posted: 06/10/09 04:30pm Link  |  Print  |  Notify Moderator
I would weigh the coach first, no need to go the "G" if you don't need too.
I replaced with "F"(original)did not want to make it ride any harder. I do wish I had put the steel stems on when they were changed.
2009 Ford Flex
Belgian Sheepdogs, Blazer & Chayna
© 2016 CWI, Inc. © 2016 Good Sam Enterprises, LLC. All Rights Reserved. | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
