Bear25314
http://www.rv.net/SharedContent/cfb/images/editortoolbar/image.gif
Bear25314
edited 05/17/12 06:58pm by an administrator/moderator *
pulsar
Lewisville, NC
Bear25314,
I reduced the width of your picture in the above post to the forum's recommended maximum of 640 pixels
See this tutorial,
Posting Pictures Using Photobucket.Com For The Host Site
Tom
captjohn57
Bay Saint Louis, MS
How can Bear post from photobucket and I can't? I get "bad response from server".
'13 Voltage 3905 Epic Pkg, Loaded, w/Full Body Paint, 7 Goodyear G614 @110PSI and a China bomb 2nd spare
'08 Chevy 3500 D/A LTZ 4x4 CC Dually
'08 Saturn Sky Red Line- Rides in the Back =-}
'06 Honda 500 Foreman
'10 Custom Club Car Golf Cart- Black n Tan
pulsar
Lewisville, NC
captjohn57 wrote: How can Bear post from photobucket and I can't? I get "bad response from server".
I don't know how to explain it to you any better than I have.
First, we don't know which portal he was using. If he was using Woodall's for example, there would be no issue.
Even if he is using RV.Net, there would probably be no issue. Here is his URL
http://i1269.photobucket.com/albums/jj585/bear25314/2013Denali287re6.jpg
Notice that there are no % symbols in it.
Here is the URL you tried.
http://i236.photobucket.com/albums/ff221/captjohn_01/2013%20Voltage%203905/2012-05-04090348.jpg
Notice the two % symbols in the middle. The RV.Net portal cannot process that, for some reason unknown to me.
BTW, the %20 in your URL represent spaces. Leave the spaces out of the names of your files, when you upload them to Photobucket and my guess is that you won't have % symbols in your URLs.
Tom
captjohn57
Bay Saint Louis, MS
Thanks Tom. I Didn't know about the spaces causing the percent symbol. I did use Woodall's portal to post some pictures. I didn't know Woodall's and RV.Net were one and the same. I thought I would have to create a new account.
Thanks again!
Capt. John
pulsar
Lewisville, NC
It's not the space directly, and it spaces shouldn't be a problem. However, certain characters can cause problems in a URL; the space character is one of them. Instead of using those characters in a URL, website encode them with their hexadecimal (base 16) equivalent. The percent sign indicates the next two characters form a hexadecimal number and should be interpreted as the appropriate character. The base 10 number for a space is 32. In base 16, that would be 20. Thus, %20 in a URL is interpreted as a space.
Again, all of that should cause no trouble. However, the RV.Net portal cannot process the %, for some, as yet, unknown reason. Thus, a space in a URL does cause a problem for the RV.Net portal.
Don't quote or copy this post. I used a "trick" to display the %. Copying or quoting the post will negate the trick.
Tom
captjohn57
Bay Saint Louis, MS
Cool! I already found out I can't quote anything with that symbol in it
DE88ROX
West Michigan. The other West Coast
TV- 2010 GMC Sierra Z71 EXT. cab
TT- 2012 Starcraft Autumn Ridge235fb
pulsar
Lewisville, NC
DE88ROX,
Hopefully you were successful. If not, make another attempt, but leave it. That will give us something to go on to provide help.
Tom
