RV.Net Open Roads Forum: Replacing bulbs with led's and being pluged into 110.....
 > Replacing bulbs with led's and being pluged into 110.....
Travel Trailers Related Tips
Fraser in YYZ
East York, Canada
Posted: 06/15/09 08:19am Link  |  Quote  |  Print  |  Notify Moderator
First off, I thought I'd start a new thread with this question rather than join in on another and have my question get lost in the shuffle.
So here goes.......I understand that switching out my interior lights with led's will work no problem when running on battery, but what about when I'm hooked up to 110 shore power? Will this just fry the led's or what?
Thanks in advance for your replies......
Fraser
DW
2 sons 14+17
2008 Jayco 213 Exp
2005 Dodge Durango 5.7 Hemi
Performance exhaust
Factory tow package
Prodigy brake controller
Husky WD hitch, friction anti-sway
McKesh tow mirrors
A bad day of camping is better than ANY day stuck in the city!!
Go Jays!
The Fisher Family
South Carolina, USA
Good Sam RV Club
Posted: 06/15/09 08:21am Link  |  Quote  |  Print  |  Notify Moderator
Your 12V lights are independent of the shore power - they will be fine!
The Fisher Family
2009 Coachmen Captiva 281DSB, 2006 Expy w/Tow Pack, Reese WD and Dual Cam Sway Control
downtheroad
Puget Sound
Posted: 06/15/09 08:23am Link  |  Quote  |  Print  |  Notify Moderator
Even when hooked up to shore power...all your 12v apparatuses (lights, etc.) operate on 12v through the battery and converter. You will be fine.
"If we couldn't laugh we would all go insane"
GMC Duramax/Allison (LBZ)
Komfort 277TS Our Rig Picture
Reese Dual Cam HP
Lots of other stuff nobody cares about
smkettner
Good Sam RV Club
Posted: 06/15/09 09:02am Link  |  Quote  |  Print  |  Notify Moderator
The LEDs will be fine, no worries.
hwybnb
Posted: 06/15/09 09:07am Link  |  Quote  |  Print  |  Notify Moderator
Try switching one fixture to LED to see if you like it before going all in. The light they put out is less bright than regular bulbs and is a much different color. Some people including myself do not like them.
tvman44
Southwest Louisiana
Posted: 06/15/09 09:13am Link  |  Quote  |  Print  |  Notify Moderator
The lights and everything else that requires 12 volts runs off the battery and if connected to shore power the converter is charging the battery so you will be fine.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
StuartW
Virginia
Good Sam RV Club
Posted: 06/15/09 09:33am Link  |  Quote  |  Print  |  Notify Moderator
I'm with you, hwybnb - I just don't like the bluish tone of the LED lighting, the uneven light distribution, or the cost. For the cost to retrofit an entire rig's worth of light fixtures to LED I can upgrade my battery bank to more than make up for any energy savings (and have all that extra power for other uses because I rarely have more than one or two lights on anyway ...).
Just my $0.02.
StuartW
2004.5 Dodge Ram 3500 Laramie
CTD HO 4x4 SRW LWB QC / Leer 100XQ cap
2005 HR Savoy SL 26RKS
PenMan
New Mexico
Good Sam RV Club
Posted: 06/15/09 10:35am Link  |  Quote  |  Print  |  Notify Moderator
First let me say that I have not switched to LED's but I'm considering it. There was another recent thread that included basically your same question. There appears to be some LED's that can't handle the higher voltage when you are plugged into AC power and your converter is charging your battery at higher than 12 VDC. As I recall, it was mainly one manufacturer that was having problems. If I come across that thread again, I will give a link to it but if you search on LED's you'll probably find it.
Chris and Jane and two boys who use a tent
2007 Rockwood Roo 23B
2006 Dodge Ram 3500, 4x4, Crew Cab, 5.9 diesel
1996 Harley Davidson Electraglide
wwest
Redmond WA
Posted: 06/15/09 11:00am Link  |  Quote  |  Print  |  Notify Moderator
Two suggestions...
Replace the "weak" OEM bulbs with halogens.
Retrofit to 12 volt flourescents.
sonicsix
Jemison, AL
Good Sam RV Club
Posted: 06/15/09 11:04am Link  |  Quote  |  Print  |  Notify Moderator
LEDs are avialable in various volt ranges, colors and light patterns. I shopped around and found LEDs that suited my needs. That being said, LEDs are not for everyone (just like any other mod).
Why We RV | Our Lighthearted Blog | Our Big List of Mods | The RVer's Library
