RV.Net Open Roads Forum: Tech Issues: AIR HORNS ON ITASCA MOTORHOME
 > AIR HORNS ON ITASCA MOTORHOME
Tech Issues Related Tips
Profcadd
Cambridge, Ontario, Canada
Good Sam RV Club
Posted: 06/15/09 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
I am still having problems with the twin trumpet air horns mounted under the hood on my 1997 Itasca Suncruiser. I determined after checking it all out that the compressor was shot. These horns operate on a 12V compressor without a tank. I purchased a new compressor from Ebay. When I press the button on the dash the motor turns in the compressor but does not sound the horns. Is it possible that the new compressor does not generate enough air? PSI. I hooked up my portable 2 gallon compressor to the hose and it produced a very loud blast from the horns. Maybe I have answered my own question???
Retired Professor of C.A.D.D Smiling Faces Going Places 1997 34' Itasca Suncruiser Coach,7.5L 460 Ford, super slide
Tow Dolly, Kia Spectra Hatchback
Best Friend companions: Sheila my wife, Oliver Yorkie, Tequilla Chihuahua, Don't leave home without them
Warren&Karen
Austin, Texas
Posted: 06/15/09 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
Indeed, I believe you answered your own question. Though I am not an expert by any means, I suspect your need mores volume and less pressure. Again, just a guess.
Karen and Warren
"Counting the days 'til retirement"
Sophie and Sam, our two Yorkies.
Austin, Texas is home. Also, look for us
at our getaway in Rockport, on the Texas Coast.
2003 38GH model Tiffin Phaeton
MrWizard
Van Nuys, Ca
Posted: 06/15/09 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
air horns or air tools, need not only pressure 40-100lbs, they also need volume, they need XXcubic feet of air per minute at that 40lbs etc.., the literature on your horns should state the volume of air-flow needed
Connected via Verizon Via Motorola Droid with Android2 OS
Profcadd
Good Sam RV Club
Posted: 06/16/09 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you for your valued input. All is well. The horns are now working. The top cover plate screws were slightly loose causing an air leak. It is a new compressor and I assumed eveything would be tight.
Thanks.
MrWizard
Van Nuys, Ca
Posted: 06/16/09 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
glad you got figured out.
thanks for posting back with the solution
