RV.Net Open Roads Forum: Truck Campers: Another happi Jack Question -- AF 990
 > Another happi Jack Question -- AF 990
Truck Campers Related Tips
rkortes
Citrus Heighs, CA
Posted: 06/16/09 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
Just got back from four days out. I went to take my camper off and my Happi Jacks won't do anything. I went to the control box where their is reference to a circuit breaker but I can't seam to locate it. The camper is plugged in with full power. Any ideas?
Truck - 2005 GMC 3500 SRW Duramax/Ali
Camper - 2006 Arctic Fox 990
The Journey Is The Destination!
CumminsDriver
Newcastle Calif.
Posted: 06/16/09 09:47pm Link  |  Quote  |  Print  |  Notify Moderator
Have you checked the fuses inside the control box?
Rich
'09 Dodge/Cummins 6.7 3500 Quad Cab DRW SLT Laramie Auto, Timbrens & Overload Bump Stop Spacers; Tork Lift Super Hitch, Tiedowns and Fastguns, ExtremeAir 12 Volt Air Compressor
'04 Arctic Fox 990; 91 Jeep Wrangler ARB's TeraLow 4.5" Rubicon Express Lift
Beddows
Abbotsford, Canada
Posted: 06/16/09 10:47pm Link  |  Quote  |  Print  |  Notify Moderator
Thefuses are a good possibility, also check the cord, & the socket. It does not take much moisture to turn those pins green and then it won't work. Most manufactuers instakll the socket with the pins on the bottom rather than th etop. Any phone guy will tell you that is a no no. Too easy for moisture to sit there or junk to fall on it. Although it looks like a standard phone cord, it is not, the pins are rolled. If you have an RJ-11 crimping tool you can make one up (sometimes you can find them at Home depot, or flag down a phone man)
rkortes
Citrus Heighs, CA
Posted: 06/16/09 11:33pm Link  |  Quote  |  Print  |  Notify Moderator
I did check the fuses. Thanks for the ideas.... I'll call the dealer in the morning.
serpa4
Vandenberg AFB
Posted: 06/17/09 09:44pm Link  |  Quote  |  Print  |  Notify Moderator
Just pulled my TC out of storage today with one jack frozen. Could hear it click. Pull gear box apart and was a stuck motor. Grabbed output gear with vise grips that just happened to have the teeth on it match EXACTLY with the splines on the motor. Twisted, sprayed with lube, all is good.
Love the camping life.
rkortes
Citrus Heighs, CA
Posted: 06/18/09 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
Update..... The hot wire connected to the 40 amp breaker under the tub on the front step (to the bed) had slipped out of the connector. The folks at Pan Pacific RV in Roseville Ca, jumped right on it and fixed it without charge.
