Open Roads Forum
Print  |  Close
Topic: Air in Water Lines/Water Pump does not shut off
Posted By: Voorheis on 06/17/09 12:00pm
Hi all, looking for help in solving a problem that has me stumped.
Trailer has a new Atwood gas water heater and when turning the pump on to draw water from the tank I am getting excessive air that will not bleed out and the pump does not shut off. I do get water out the faucets but it kinda of sputters and flow changes. I do not have the problem when a hose is hooked up to the outside connection to bypass drawing from the water tank.
I have checked all fittings and do not find any leaks and have tightened the connections with new hose clamps at the tank outlet and connection to the plumbing lines inside to make sure I was not drawing air in before the pump inlet.
Any ideas or suggestions on what I might be missing? Thanks in advance for any help.
Posted By: jerryspoolman on 06/17/09 12:05pm
I had the same problem years ago on my boat.. Ended up having to relocate the water pump lower than the water tank.
Just Jerry and Vangie
Posted By: 2oldman on 06/17/09 12:10pm
Is the new water heater full of water?
Posted By: 12th Man Fan on 06/17/09 12:27pm
Make sure all of your control valves are in the proper position. If my valves are not in the proper configuration it will not prime.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
Posted By: dbbls on 06/17/09 12:51pm
That is what mine does until the water tank is full. Leave a hot water tap open until a full stream of water comes out, then shut it off.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
Posted By: cpwomer on 06/17/09 12:54pm
There is an adjustment on a pump for pressure. Its a small screw on the end of the black nose and there are arrows going in either direction for increase or decrease, but by experience never adjust more than a quarter turn at a time. To much and it won't turn off to little and it won't turn on. Most pumps are installed where your looking at the motor butt. And you can't access the screw. so I added flexible hose so I could turn it around. Adjust it with the furthest water on. My pump is in the back so I use the kitchen cold water on up front and slowly increase till you get an even flow on the pump. Then test each source one at the time. Then try two. By then you will get the hang of it. Worked for me all the time.
The Ark 91 PACE w/ 4dogs 1cat,
Posted By: 2oldman on 06/17/09 02:58pm
How long have you tried leaving the pump running? I've had occasions where, after draining the tank dry then refilling, it can take 5-10 minutes (provided the HW is full) to bleed the system.
Posted By: Voorheis on 06/18/09 01:18pm
I should of mentioned this is a new trailer to me but had one previously and this one seems a little different.
There is no fill valve to turn on/off just a hose connection on the outside.
The only shutoff in the system besides 2 drains that dump out under the trailer is just below the water pump with a line that runs horizontally from the vertical pump inlet line to the vertical pump outlet line. When that is in the on position no water at all comes out the faucets. Closed does allow water flow but sputtering and no pump shutoff.
Posted By: Hamops on 06/18/09 08:36am
mockybird wrote:
Check near your pump for the hose that you siphon AF thru to do winterizing. Make sure it is in the closed position
This is the most likely reason for the air getting into the system.
Helen & George VE3INB and Max (Bichon Frise)
2006 Silverado 2500HD D/A, Isspro Gauges, Linex, Westin Nerf Bars, Fold-A-Cover
2014 Avalanche 295
Reese 16K Slider, Bedsaver, Prodigy Controller, Rearview Camera
Posted By: Grizzly128 on 06/17/09 08:27pm
Check "winterizing valve" is closed......
if you have tank fill/city water inlet,make sure it is in proper position.
Posted By: talotto on 06/17/09 05:09pm
Make sure your water fill valve isn't in the "fill" position, needs to be in the same position as if you were using tap water. In the fill position the pump will run constantly and draw air into the lines.
2004 Itasca Meridian 36G
2004 HD Heritage Softail
2016 Jeep Wrangler
College Station, TX
Posted By: Voorheis on 06/17/09 02:40pm
Thanks for the responses so far.
The water heater appears to fill with water as I can open open the relief valve and get some air before steady water. I do hear some gurgling noises in it though.
I can see air bubbles in the water lines and even leaving the faucets open for a while does not bleed it all out.
I tried the pressure adjustment screw on the pump with no changes.
Air seems to be entering somewhere but can not determine where and can not get the pump to shut off.
Posted By: mockybird on 06/17/09 03:01pm
Print  |  Close
