RV.Net Open Roads Forum: Tech Issues: Official Honeywell Generator thread..talk about em here!
 > Official Honeywell Generator thread..talk about em here!
Page of 21
Tech Issues Related Tips
MrWizard
Van Nuys, Ca
Posted: 09/06/09 11:25pm Link  |  Quote  |  Print  |  Notify Moderator
3 HW gennies for $400 Canadian, I think a few people are going to want to know the name & address of your seller..
Connected via Verizon Via Motorola Droid with Android2 OS
83trekker
calgary,ab,canada
Posted: 09/07/09 09:31am Link  |  Quote  |  Print  |  Notify Moderator
Im in the works of buying up all there supply, pretty sure i can get them all working. Then i will sell them off.
83trekker
calgary,ab,canada
Posted: 09/07/09 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
Does your honeywell in eco mode run really smooth?
PrivatePilot
Courtice, Ontario, Canada
Posted: 09/07/09 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
83trekker wrote:
Does your Honeywell in eco mode run really smooth?
In eco mode, with zero load, mine does not idle smoothly - the governor seems to bounce the idle up and down, not finding a middle ground where it can settle down.
With a little bit of load, it settles into a smooth RPM range and stays there though.
I've considered calling Honeywell and seeing if there's anything I can do about this. It is a bit irritating when the genny is running under such light load (while in standby waiting for a load for example) and it's bouncing all over the place RPM wise.
30' Keystone Cougar 5'er, Triple Bunkhouse, SuperSlide.
Chevy 3500 1 Ton long box crew cab dually
6.5 Turbo Diesel, 4.11 Rears, LSD
Miles towed in 2008: 12,900 Kilometers, 7990 Miles
Checkout my blogs, adventures, and more here!
Mark
Wayne Dohnal
Banks, OR.
Posted: 09/07/09 09:32pm Link  |  Quote  |  Print  |  Notify Moderator
This uneven idle is a fairly common problem with the eu2000i. Partial choke smooths it out, and the cause is a gummed up carburetor.
2009 Fleetwood Icon 24A
LinkPro battery monitor
EU2000i generator
83trekker
calgary,ab,canada
Posted: 09/07/09 09:43pm Link  |  Quote  |  Print  |  Notify Moderator
Thats how mine runs eco, but in full throttle runs awsome, dont have the other ones at my place to run them long enough o try them.
MrWizard
Van Nuys, Ca
Posted: 09/07/09 11:44pm Link  |  Quote  |  Print  |  Notify Moderator
you can try turning the plastic screw on the carb, in 'clockwise' a little bit 1/2 to 1 turn. also a new engine is going to be a little tight
83trekker
calgary,ab,canada
Posted: 09/08/09 08:33am Link  |  Quote  |  Print  |  Notify Moderator
Can a really gummed up carb prevent the engine from starting at all? Or will it just run really bad?
MrWizard
Van Nuys, Ca
Posted: 09/08/09 11:31am Link  |  Quote  |  Print  |  Notify Moderator
either / BOTH
when i was , buying and selling mopeds, one of the first things i did was disassemble the carb and soak it in a bucket of parts cleaner ( do not soak the gaskets an orings )
83trekker
calgary,ab,canada
Posted: 09/08/09 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
Starting to find that the primer bulb on these things might become the weak link with them. Im going to try and find a after market one and see how that helps with starting. Ill keep you updated, if that was the faxt it would be cheap to replace.
Page of 21
