RV.Net Open Roads Forum: Tech Issues: Official Honeywell Generator thread..talk about em here!
 > Official Honeywell Generator thread..talk about em here!
Page of 21
Tech Issues Related Tips
BallsDeep
Thousand Oaks, Ca
Posted: 09/23/09 09:55am Link  |  Quote  |  Print  |  Notify Moderator
BallsDeep wrote:
I recently purchased a new Honeywell generator for my TH. The TH has an Onan 5k in it already; I was hoping to use the Honeywell as a way to keep the hours down on the Onan. So far, the Honeywell is descent for the money but is still pretty loud. I read through all 15 pages of this post and the noise factor seems to be a consistent topic. Has anyone pulled this apart and tried putting dynamat or foam of some sort to help quiet it down? I was gonna try to do this to my unit but wanted to see if anyone had experience and if it made much difference
UPDATE- I went to my local Pep Boys and purcashed a roll of Dynamat to help dampen some of the sound. I pulled the generator apart and stuck the Dynamat in the appropriate places and it still didnt really help with the noise levels. Guess I cant complain to much for the money spent, I can always turna round and sell it. The generator would be perfect if the noise levels stayed at the lowest level with no draw when geny is idling.
Please let me know if you have any other suggestions on quieting this usit down more.
22R
Gonzales, LA
Posted: 09/23/09 11:47am Link  |  Quote  |  Print  |  Notify Moderator
How bad was taking it apart and getting it back together ? Did parts want to spring out all over the place ? I would have thought that it would have made it less noisy. Has anyone tried to put a regular primer in place of the one they have on it that will shoot gas into the carb. Other that hard to start mine seems to be OK for the money.
Ain't no HONDA though !!
22R
83trekker
calgary,ab,canada
Posted: 09/23/09 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
22R
Soon but in the line with the fuel filter.
racefan1965
Redding, Ca.
Posted: 09/23/09 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
PrivatePilot wrote:
Does anyone else have a metallic rattling noise (high pitched) coming from theirs?
Mine has had one since hour zero and I can't narrow down what's causing it. It's not even noticable from some angles but at other angles (facing the exhaust side) it's a slight "pinging" that can be maddening after a while.
Ours is outside puttering away as I type this - we're boondocking for the weekend. Still pleased overall (It's a heck of a lot quieter then my old Champion) but the pinging noise is getting to me.
Is that pinging noise odd sounding? Sort of like someone tapping on a odd sounding bell continuously? If so I think I might have the same sound.
Rick, Shirley, Lacy, Misty and 2 dogs(Shasta & Baylee)
2003 Ford 250 Superduty 4x4 LB 6.0 Diesel
1999 Dodge 2500 Quad Cab 4X4 gasser
1984 Alpenlite24 5er
1988 Coleman pup
2006 Champion C46540 RV plug ready genset
2009 Honeywell 2000i inverter genset
PrivatePilot
Courtice, Ontario, Canada
Posted: 09/23/09 08:30pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, I'd say that describes it. I've ruled out a loose screw or nut rattling around inside the unit as it's simply been through too much "rocking and rolling" while traveling for anything like that to be still making noise. I suspect something inside the recoil, personally.
I'm taking mine to the service depot tomorrow to get it looked at for the no-output issue. If the jingling noise gets resolved at the same time I'll consider it a bonus.
30' Keystone Cougar 5'er, Triple Bunkhouse, SuperSlide.
Chevy 3500 1 Ton long box crew cab dually
6.5 Turbo Diesel, 4.11 Rears, LSD
Miles towed in 2008: 12,900 Kilometers, 7990 Miles
Checkout my blogs, adventures, and more here!
Mark
racefan1965
Redding, Ca.
Posted: 09/24/09 02:59am Link  |  Quote  |  Print  |  Notify Moderator
Keep us updated please. I have about 14 hours on my genset and I would rather it went out while under warranty than after it expires.
PrivatePilot
Posted: 09/24/09 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
Dropped it off at the service center this morning. Will report back what the results are.
Old & Slow
Posted: 09/25/09 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
I wrote to a man by the name of 'China Dave' @ Allexperts.com and ask this question. "Are the engines on most new Chinese Inverter gensets from a past Honda design"? The answer was 'yes'.~ Are they out of the same factory with same quality, I don't think so. We can all ask are the K/O's equal to one with the name of Honda on the the genset? Is the Honeywell a close copy? Maybe some one will put them side by side and give a full report?
83trekker
calgary,ab,canada
Posted: 09/26/09 09:36am Link  |  Quote  |  Print  |  Notify Moderator
When i tore one of mine right dowm, i was impressed with the engine on the honeywell overhead cam, timining chain, but the whole fuel system is the weak link IMHO.
On another note;
The gen has compression, good spark, the bowl is full of gas but wont start no matter how many times you pull it. What can it be? If theres gas in the bowl can it still need more?
MrWizard
Van Nuys, Ca
Posted: 09/26/09 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
it needs to suck the gas thru the main jet
if the jet is clogged if any ports are clogged in the carb or if there is a vacuum leak some place, it won't vaporize the fuel
try removing the fuel pump vacuum line from the intake manifold and plug/cap the nipple on the manifold. the fuel pump won't run , but if the engine starts, you have narrowed down the problem.
Connected via Verizon Via Motorola Droid with Android2 OS
Page of 21
