Dave H M
IL
I would search far and wide before I installed another hunter. It works fine but I would really like another feature. It seems that it is not always as light in the area the stat is and at night I sometimes use a flashlight to check and set.
I would get a model that has an illuminated face that turns on when you touch a button.
Mine will be that way some day and the hunter will be in the sanitary land fill.
bhoth
Utah
Dave H M wrote: I would search far and wide before I installed another hunter. It works fine but I would really like another feature. It seems that it is not always as light in the area the stat is and at night I sometimes use a flashlight to check and set.
I have installed two of the Hunter model 44260, they have the indiglo display. We love them!
sue.t
Vancouver Island, BC, Canada
I installed a programmable Honeywell. It has a display that illuminates and also had three different coloured faceplates (black, grey or tan). It is a 5-1-1, which means we can program Mon-Fri, Sat, Sun all with unique settings. It also lets you program all 7 days at once, if your setting will be the same for all days.
The override function is handy too. This lets me temporarily adjust the temperature within a time setting (it has four different time settings: wake, leave, return, sleep). We're usually out of the fifth wheel by 9 a.m. so I have the temp set lower after 9 a.m. But sometimes we're lazy and still hanging around, and rather than reprogram it's nice to just be able to override the setting for that period.
sue t.
Pictures from our many RV Adventures to Yukon & Alaska
Mayoman
Tennessee
mayorna wrote: Mayoman any relatives in centeral IL?
Sorry, I don't.
2008 Ford F450 Superduty Diesel dually
2005 Mobile Suites 36TK3
B&W Companion Hitch
emmaspride
Southern MI USA
Probably a dumb question, but our furnace/ac work off a remote control...could we install a Hunter for that?
RAINEYTXX
Texxxas
sue.t wrote: I installed a programmable Honeywell. It has a display that illuminates and also had three different coloured faceplates (black, grey or tan). It is a 5-1-1, which means we can program Mon-Fri, Sat, Sun all with unique settings. It also lets you program all 7 days at once, if your setting will be the same for all days.
can you give me the specifics on your install and thermostat...? Do you have 2 ac's?
Dave H M
IL
thanks bhoth and Sue
I have copied your posts and will use that to shop for the replacement for the hunter that I now have installed.
Dave
sue.t
RAINEYTXX wrote: can you give me the specifics on your install and thermostat...? Do you have 2 ac's?
We have one a/c. Our thermostat, which has a heat and cool setting, operates the a/c at one fan setting only, which isn't an issue for us since we rarely use a/c. Some folks install a separate switch to control the fan speed settings.
Don't remember specifics on the install ... we followed the numerous directions available on line and it all worked perfectly afterwards.
robertbick
Upstate NY
One of the best and easiest mods out there. I've done it twice.
Bob
2008 Chevy Silverado 2500HD 4X4 LTZ
2010 Keystone Cougar 276RLS Pictures
PullRite Superglide 14K Hitch
