RV.Net Open Roads Forum: Travel Trailers: Toilet paper
 > Toilet paper
Travel Trailers Related Tips
mhawk4
South Carolina
Good Sam RV Club
Posted: 06/20/09 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
bondguynbondgal03 wrote:
Toilet Paper . we all use it. lord knows we've all been caought without it. But, in an Rv not only is it a necessity but a very expensive commodity. My wife and I are new to rv'ing.We have recently come across a product called Exodor BIO-PAK manufactured by WALEX Products Company in Wilmington North Carolina. The claim is it eliminates the mess but also... and here's the big one the need to use special rv toliet paper in your rig. I'm knew but I'm not stupid. Well, I did but an RV, but I digress. Has anyone else every heard of it used or Did I just waste my time and money. It sounds great but is just another one of those to good to be true stories I usually find myself in again.Thanks.
Always had the same question!
thanks for the post, i will stop buying rv tp, and will go with regular
cheap brand
2002 Ford Excursion XLT 6.8L,V10 3.73(TB2)
1999 Chevy Suburban 5.7L,V8 3.73 (BUDDY)
2008 Jayco G2, 27BH (MHAWK)
HP dual cam
Luis,Shelia,Noah,Gabriel
All about the family!!
bobbyg123
Duvall, WA
Posted: 06/20/09 11:18pm Link  |  Quote  |  Print  |  Notify Moderator
I'm a new RV owner myself, and I put this subject to a simple test. Mix a couple of sheets of single-ply TP (unused) in a glass of water. The brand we bought disintegrated instantly, so it passed the test.
I will say this; however. It's critical that you don't get careless with your TP purchase. Our plumber showed me a similar test between commonly used TP brands. There are some that are "treated" to more durable and/or to accommodate patterns/textures, etc. Some of the stuff will NOT break down for several minutes when resting on the surface of your toilet water. I was pretty surprised. Check the brand you're using in your home by crumpling up a few sheets in your hand and drop them in the toilet water. If they don't absorb water IMMEDIATELY, switch TP brands. It's a clog waiting to happen. Same with your RV. Single ply (or double, as long as you use enough water) that disintegrates with water on contact.
2008 Jayfeather 29A
2007 Ford F-150 5.4L V8
UC Patriot
East Central Mississippi
Posted: 06/21/09 04:39am Link  |  Quote  |  Print  |  Notify Moderator
As long as it is good for use in septic systems, it's good for use in RV.
Bumpyroad
Virginia
Posted: 06/21/09 04:57am Link  |  Quote  |  Print  |  Notify Moderator
Arn wrote:
It's a holding tank, not a septic system. Who care if the paper decomposes? You're going to dump it soon anyways. Just make sure you use lots of water so none of the solids dry out & harden in your tank.
x2
bumpy
kfc
SC
Posted: 06/21/09 06:09am Link  |  Quote  |  Print  |  Notify Moderator
In our first TT we had a clog while using the special RV toilet tissue. We just weren't using enough water to flush the tank. What a mess. We now use Scotts and lots of water. I hate to think of all the money that I wasted buying the special RV toilet tissue, when the Scotts that I already used at home would have worked just fine.
aquarious
Marion Indiana
Posted: 06/21/09 07:15am Link  |  Quote  |  Print  |  Notify Moderator
I use regular tp and plenty of water and have never had a problem. Did I mention I use plenty of water ?
nuff said
P. S. Use plenty of water.
Leaf-Peeper
Small Town, USA
Posted: 06/21/09 07:43am Link  |  Quote  |  Print  |  Notify Moderator
Toilet paper science fair experiment << This be a clicky.
The scientific tests results had concluded favorable results using Angel Soft brand of toilet tissue. Based on the test results, we switched from Scott single ply (not the wife’s favorite) to Angel soft. She finds it has much more softness and I find no visual signs of it, nor any clumping when dumping using the clear flush king adaptor.
'05 Chevy Tahoe & ’08 Rockwood Roo 23ss
'62 Myself
'62 Camper Honey
'96 Camper Twin Girls
Pictures of our '08 23ss Rockwood Roo & Our Mods on Webshots
mowermech
Billings, MT
Posted: 06/21/09 08:49am Link  |  Quote  |  Print  |  Notify Moderator
There is a true statement!
CM1, USN (RET)
'94 Dodge 3500 4X2 CTD, 5 speed, 4.10 LS diff., Jacobs Rambrake, 274,000 Miles
'99 Monaco McKenzie 32' triple slide
'95 Tioga 29H Ford-based Class C
Daily driver: '08 Subaru Outback
Towed: '06 Jeep Rubicon Unlimited/Load Trail 16' flatbed
wrenchbender
Phx
Posted: 06/21/09 11:50am Link  |  Quote  |  Print  |  Notify Moderator
We have used the Costco brand for 30 yrs and have no problems.The paper labeled as septic safe is the only criteria.
marc71
South East VA
Posted: 06/21/09 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
How about 4 brown corn cobbs and one white one
2002 Toyota Tundra SR5 TRD 4x4
2003 Keystone Springdale 268 BHL-GL
Prodigy Brake Control
Eaz-Lift WD - Eaz-Lift sway control
 > Toilet paper
