RV.Net Open Roads Forum: 1st trip out with new rig...a couple questions...
Open Roads Forum  >  Hybrid Travel Trailers
 > 1st trip out with new rig...a couple questions...
Hybrid Travel Trailers Related Tips
flamelily
austin
Posted: 06/21/09 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
Well it went very well....no glitches...I did have a question or two though...
Most refrigerators run on both propane or electric...and when plugged in to electric the refrigerator knows that it automatically goes and uses electricity..not propane, right? I dont see a switch anywhere that says Propane or Electricity...I heard Electricity automatically takes precedence...
Dumping the grey/black water all seemed to go so well I cant help but think we forgot something..this is what we did:
...we dumped the black tank once it was almost full....then left the line open and ran the toilet for a minute....then closed the black tank, opened the grey and dumped the grey...does that sound like a good plan?
Anything else to do dumping wise to make it all good?
Thanks for any thoughts...
P.S. The roos are awesome--takes maybe 5 minutes to get those bunks out and open!!!!
bikendan
Napa, Cal.
Good Sam RV Club
Posted: 06/21/09 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
the only thing is once you dump the black tank, to put back at least a couple of gallons of water. we also dump our ice in there to help scrub the black tank on the drive back home.
Dan- Firefighter, Shawn- Musician/Entrepreneur, Zoe- Faithful Golden Retriever, 2007 Chevrolet Avalanche LS, 2007 Rockwood Roo 23SS w/Equalizer and Prodigy, and 5 Mtn. bikes and 2 Road bikes
johnthecamper
Grapevine, TX
Posted: 06/21/09 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
As far as the refrigerator ours has a switch right on the front of the frig. for automatic or gas only. On the auto setting it senses whether you are plugged in to electricity and then it switches to either gas or electric.
08 F250, 08 Jayco 29D
Nickelchew
Concord, NC
Good Sam RV Club
Posted: 06/21/09 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
I leave our fridge on Auto. When hooked up to electricity, thats what it it runs on. When you pull the power, it switches to propane (Assuming you have the tank valve open).
As far as dumping...It sounds like you did it right. I have one of those high pressure wands that I stick down the hole to rinse the black tank after dumping. After that I close the black and dump the grey. I then add chemicals and about 2 or 3 gallons of water to the black tank.
2009 Rockwood Roo 21ss
2006 Toyota Tacoma Prerunner TRD W/Factory Tow Pkg
Prodigy, Equalizer WDH
Chuck&Gail
In the Colorado Mountains
Posted: 06/21/09 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
Well I fill kitchen sink with warm water. Then dump black, then dump gray. Then add 1 gallon (one toilet full) of water to black so it doesn't dry out. Then once hoses stored and ready to go, I use warm water to wash hands with soap. Once sink drains, gray has as gallon in it also.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
sclark
Minnesota
Posted: 06/21/09 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
Good advice so far. As mentioned above, keep a few gallons of water in the black tank. I think it is best not to let it get dry. Anything inside will turn to a solid causing problems later. Good luck with your new rig.
2004.5 Dodge Cummins
2007 Wildcat 32QBBS
Pair of Honda 2000 Watt generators
flamelily
austin
So normally you all leave a couple gallons either in black or grey or both? That is good to do? What is the purpose of that? I didnt realize I should leave something in the bottom of the tanks...
This forum is so awesome...thanks so much...
flamelily
austin
Posted: 06/21/09 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
sorry....didnt see the above mine post regarding leaving some water in the tanks...thanks...
Terryallan
NC
Good Sam RV Club
Posted: 06/21/09 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
Great idea. I usually just wash at the site faucett, or bath hous. But this is good.
Terry & Shay
Pioneer 23T6
04 F150, 5.4, Lariat SuperCab
Lazy Campers
NC
Chuck_S
Broadview Hts, OH, USA
Posted: 06/22/09 08:08am Link  |  Quote  |  Print  |  Notify Moderator
As for the tanks it's an easy clean enroute to your next campground. Put enough water and maybe some Tide in both tanks that they slosh clean and dump the tanks when you enter the campground -- there's never a line there on entry.
-- Chuck
'06 Roo 23SS behind '07 Expedition out of Cleveland
Our Photo pages
