proptwister
SW Missouri
Good Sam RV Club
I contacted my dealer about the tire. They have bent over backwards in trying to rectify this. I am bringing the unit in Monday to have the second air installed and was told by the owner that one way or another, they will all be replaced at no charge. I will pay close attention as to what that replacement is.
I'll keep you posted on what happens.
Thank you for all your replies.
Matt
07 LMM CrewCab Short Bed Duramax/Allison 2500 HD
Banks Six Gun/Intake/Exhaust
Banks Speed Brake
Airlift 5000# Airbags
B&W Companion Hitch
07' 3814SS Raptor Toyhauler
5th AirBorne Pinbox
Dwight45
Kansas
So, they are still suppling Raptors with 15" wheels? I think the only E rated tires for 15" rims are Chinese. I converted my 05 to 16" and I'm using Uniroyal LT E rated tires. No problems in around 6K miles. Run them at 80psi and check air and temp often.
Dwight
Chuck&Gail
In the Colorado Mountains
Maxxis makes 15" E rated tires. They are not Chinese, at least mine are not. But OP still has D rated WHEELS!
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
HarleyMedic
Sour Lake, Texas
Good Sam RV Club
Running Michelins without any problems. The BFGs and Firestones are good tires also.
Big Sexy and BonBon
2006 F-350 King Ranch SRW
2004 35SRV Victory Lane
1998 Harley Road King (Mine)
2003 Harley Road KIng (Hers)
2004 Yamaha Grizzly LE
2008 Yamaha Rhino
studio5o
Nor Cal Bay Area
runnin BFG's on my 30 ft. tag and on 16.5 rims......does really well and total confidence going down the road here's a pic...
DuneMe
Elk Grove, CA
I had the OEM Transmaster tires. Started to get checking around the rim so, replaced them (well - actually 4 of 6 of them that had checking) last year.
We got the Goodyear Marathon tires to go on our 16" rims.
The Michelin's look to be one of if not the best tire out there but, if you need to air-down to go through the sand, you won't get them to air-down at all.
Don't get me wrong - I prefer to not air down the tires at all. I hope the sidewalls hold-up well but, that always concerns me.
The Michelin's were also a different size tire than what I had so, I would have had to replace all 6 tires. If you are looking at replacing all tires - the Michelin's should be on the top of your choice list. Start saving your pennies.
2005 GMC Sierra 4X4
Duramax Diesel - Edge w/ Attitude / 4" exhaust / Cold Air Intake
45-gallon TransferFlow Tank
4" Lift
Air Bags
Weekend Warrior LE3905 Toy Hauler
Raptor 700's for the Wife & I
Raptor 250-Daughter's
RZR-S
trailerjack
You will get all kinds of advise and all kinds of reasons for your tires blowing out.You will not hear the experts tell you that there is not a not a quality tire available.My 2002 Wildcat came equiped with Carlisle ST225-75-15 D tires.In two years all the three tires had blown out and one tread separation.While negocating a settlement with Carlisle I put on a set of Goodyear Marathon.These plus another two more failed or blew out.I had found out after buying the Goodyear tires that my origional Carlisle tires were made by Goodyear as that was who paid for my trailer damage.Carlisle replaced my origional set with five new tires sent to my home.I have since blown or replaced these tires due to defects,three tires total that had tread separation issues.I have been replacing tires now with Carlisle E rated tires and since then have blown out one tire.There was not 1/64 of wear on that tire.Forums will tell you your tires are old while my tires were never older than three years.They will tell you that your trailer is overloaded while knowing my trailer was not I spent the nine dollars for weigh scales and found my axles had 7700# load when I was fully wet and loaded on a trip.Thats over 2000# under.Failures have occured on both sides of the trailer and on both axles.They will tell you it is your axles yet my tires do not exibit abnormal tire wear.They will tell you that your tires are underflated.I have been an RVer for over thirty five years and have had two Tonge pull,5th wheel,Cabover and Mini Motorhome campers plus many cars,trucks & trailers and not had tire issues.They will not tell you that tire manufactures are not building a good tire and they could make a better tire. They will not tell you that DOT does little or nothing about these problems.They will not offend advertisers.What you need to do is what I have done.Buy a good hydraulic jack,an electric impact wrench,carry two extra spare tires under your sofa(these tires can be hard to find),save all bad tires and return them to your good hometown dealer for adjustment and pray you do not die changing a tire.Good luck on American tires too because it doesn't seem to matter where their made and seems their all made in China now.
chipworkz
California
On a side note, did anyone see the special on Fox News about China dumping junk tires at cheap prices on us? Some people are wanting to add a tax to the tires so they won't be so cheap and the the China companies will have to step up the quality to be competitive. Others are saying we can't do it, good old politics!
I didn't get all the details since I only caught a little bit of it but at least it is starting to be looked at.
2002 GMC 2500HD ext cab LB SRW 8.1 Allison P3 controller Reese 20K air lift bags Rancho 9000's
2009 MVP Tahoe 395 TIB
08 KFX 450R
07 TRX 400 EX
07 TRX 250EX
92 KX 250
Custom Sandrail
