RV.Net Open Roads Forum: Fifth-Wheels: Water Pressure regulator
 > Water Pressure regulator
Page of 5
Fifth-Wheels Related Tips
WellShooter2
SE New Mexico
Good Sam RV Club
Posted: 06/26/09 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
I have a cheap one, I use it, I hate it. Is it necessary? Anyone ever have a water line blow inside your RV? Did you have a regulator at the time.
waroland
Mt. Juliet, TN
Good Sam RV Club
Posted: 06/26/09 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
Years ago I had a pop-up camper and dad several connection blown by high water pressure. The campground manager said the pressure would get up tp 90psi sometimes. I have used a regulator ever since. I recently purchased this one from HD in the sprinkler section. Regulator
2007 GMC Sierra 2500HD SLE 4wd crew cab
2004 Keystone Challenger 32TKB
FXSTOHIO
Ohio
Good Sam RV Club
Posted: 06/26/09 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
I was just in a camp ground that had warnings notices posted all over the office that the water pressure was 60 lbs plus and to use a regulator.
2008 Pilgrim Lite 21LRB
2004 Chevy Silverado Extended Cab 4x4 5.3 Tow Pkg 3.73
Yamaha EF2400IS
crickeydog
Marietta, Ga.
Posted: 06/26/09 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
WellShooter2 wrote:
1. Is it necessary? 2. Anyone ever have a water line blow inside your RV?
1. Yes
2. No, because I use a regulator. We camped next to a couple in a very nice MH in a Nashville CG a couple of years ago. They were not using a water regulator and also failed to turn off the water supply to the MH while they were away for the day. When they returned in the late afternoon, they discovered a water line under the kitchen sink had split under pressure. It was a sorry mess.
Happy camping!!! See ya'll down the road!!!
USAF RETIRED
2006 GMC 3500 CC DRW D/A 4X4 SLT,PREDATOR,VOLANT CAI,FS2500 OIL FILTER'S
2004 HR PRESIDENTIAL 30 SCD.
CHEROKEE & CHEYENNE MINI DOXIE'S. WE'RE IN CHARGE!!
LOADED LIKE A FREIGHT TRAIN, FLYIN LIKE A JET PLANE.
IT'S 5 O'CLOCK SOMEWHERE!!
Chuck&Gail
In the Colorado Mountains
Posted: 06/26/09 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
We stayed in a CG recently that had a sign at registration warning to use pressure regulator. Next morning you could tell by the cursing and shouting who didn't use a regulator. Saw several trailers with water pouring down their steps. Lots of broken pipes. It is your rig, so you can do as you wish, but WE are not hooking up without one.
Why do you hate the regulator? If shower pressure is too low, did you remove the stupid government mandated flow restrictor yet? Is pressure ok using water pump? What is the problem, maybe we can help?
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
Dennis Bham
Alabama
Posted: 06/26/09 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
I have encountered pressure up to 90 PSI ... IMO you need one ...
You need to look at the flow rate (GPM) because cheap ones have limited flow rates.
I recommend Watts 263A 4-4.5 GPM
http://www.rvwaterfilterstore.com/PressureRegulators.htm
'08 Chevy 2500HD Duramax 4x4, Crew Cab, Std Bed e/w 18K Superglide
'08 Cougar 292RKS, e/w 16" Sendel wheels & BFG Commercial TA tires
PressurePro TPMS
Puddles
Lafayette, Indiana
Posted: 06/26/09 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
Right on... GPM is the key... get a watts adjustable pressure regulator.. it's flow rate is much higher than the fixed rate ones... Home Depo.. Lowes
HTML
WellShooter2
SE New Mexico
Good Sam RV Club
Posted: 06/26/09 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
Yep flow rate is too low. Like I said it is cheap, and I have considered leaving it out of the line, I never have and now you have all convinced me to upgrade. Thanks for the input.
RedG
Good Sam RV Club
Posted: 06/26/09 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
I've got the N55GP from the same site. World of difference.
2007 Chevy Silverado 3500HD Crew Cab Dually Duramax/Allison
2008 Jayco Designer 35RLTS
old guy
Oregon (pronounced Or e gun)
Posted: 06/26/09 11:15pm Link  |  Quote  |  Print  |  Notify Moderator
one thing is the cheap ones are just that cheap stuff and they don't work worth a hoot. I have seen white hose swell up like a snake that just ate a small deer.. It can and does happen. I just don't want to clean up the mess so I use a regulator.
Page of 5
