RV.Net Open Roads Forum: Fifth-Wheels: Water Pressure regulator
 > Water Pressure regulator
Page of 5
h2guy
Ain't seen a sign yet!
Good Sam RV Club
Posted: 06/30/09 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
If you stay in Electric City WA or anywhere around Grand Coulee Dam, you WILL need a regulator.
Signs everywhere there warn of 100+ lbs of pressure as "normal".
Rick & Carolyn
01 Ford SC 4x4 DRW
01 CarriLite 5ver
Showme 5vr
Belton, USA
Good Sam RV Club
Posted: 06/30/09 09:16pm Link  |  Quote  |  Print  |  Notify Moderator
Don't mean to hijack this thread, but sirdrakjr could you define "get legs"
Steve & Judy 2007 Dodge 2500 5.9L Cummins Quad Cab LWB, 2003 Jayco Eagle 263RKS
moterman
Fl
Posted: 07/01/09 06:01am Link  |  Quote  |  Print  |  Notify Moderator
I had the same problem got a high flow regulator and oxegenics shower head no more problem
bruce@melanie
al E. gator the cat
95 K2500 tricked out
07 surveyor 5th wheel
Dayle1
Spicewood, Tx
Good Sam RV Club
Posted: 07/01/09 08:07am Link  |  Quote  |  Print  |  Notify Moderator
What most people have failed to state is that the regulator should be used at the faucet so that it protects both the RV and the hose. In light freezing weather this could make the difference between a safe hose and a ruptured hose.
We do volunteer work at a camp that has high pressure and the RV park is split into several levels. Well the hose on a camper on the upper level did rupture at night and the next morning the lower level had several inches of water everywhere, so we put up a sign calling it "Shaefer Lake". Ken never made the same mistake again.
Larry Day
Texas Baptist Men-Retiree Builders since '01
'03 GMC 2500HD D/A EC SB, Jordan controller, custom RKI bed/hitch, Putco boards, TF 45gal tank, grey Speedliner
'04 CrossRoads Cruiser CF29RK, Mor/ryde IS, Carefree Eclipse 12V awning
Rig Photos
2003f350
Coventry, RI 02816
Good Sam RV Club
Posted: 07/01/09 09:15am Link  |  Quote  |  Print  |  Notify Moderator
I believe He is thinking that someone may like it amd remove it when
no one is around.
Ed
Ed & Shirley.
Truck, 03 F-350, 7.3 PSD, 4x2 Supercab, Lariat, Long bed, Toreador Red and Arizona Beige., Rhino liner, Reese 16k hitch, Prodigy Brake Controller, Custom-Flow Tailgate, C-Betr Mirrors.
Camper-02 Thor Citation 5th. wheel, model 295P
DrTanTodd
Sioux Falls, SD
Posted: 07/01/09 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
Chuck&Gail wrote:
If shower pressure is too low, did you remove the stupid government mandated flow restrictor yet? Is pressure ok using water pump? What is the problem, maybe we can help?
Never heard of this ? How do you remove that restrictor?
2009 Dodge 2500 Quad Cab 6.7 Cummins,Auto, 4X4, Shortbox
2010 Forest River Wildcat 31TS
Todd and Dawn with Oliver and Maddy the Cats
Our Photo Page
graybeard
Elizabeth, CO USA
Posted: 07/03/09 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
Next time you are in your local hardware store, pick up a cheap (unpackaged) shower head and look up the water flow path from the threaded end. See that little hole in the plastic disk?? That's the Government Interference Disk (GID) that Chuck mentioned. Slow use of a drill bit of yur choosing can help that a LOT.
You are probably breaking some Federal Law, however. It works better then.
Empty Nesters
2001 R-Vision 7250
2007 Nissan Titan CrewCab
3.33 gears, 4x4, Ham Radio Aboard
emtee
West Virginia
Posted: 07/03/09 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
I just moved to a new campground last night. MEASURED water pressure is a whopping 92 PSI!!!! I don't know how the guy keeps his CG water system together. Anyway...
Watts regulator @ 55 PSI. Installed at the fawcett. Good to go. I sleep well at night.
Mark and Lucy T.
2004 Chevy 2500HD 6.0 liter "Fe Balls"
2008 Jayco Eagle 27.5 RKS Super Lite
Superglide on Homemade Removable Rails
Trlrboy
Rockwall, Texas
Good Sam RV Club
Posted: 07/03/09 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
I've been using a Watts N55BG for a couple of years and it works well. I keep it set at 52# and that seems to give us good flow in the trailer.
Crossroads Cruiser CF29RK
Chevy 2500HD Duramax/Allison
TRLRBOY PHOTOLINK
USA in a Chevrolet
Manahawkin, New Jersey
Good Sam RV Club
Posted: 07/03/09 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
dsprik wrote:
I had a good one and I put it away. Most of the year we spent in one CG. It ran a whopping 32 lbs press on a good day. Sometimes, we filled the onboard fresh water tank and used our onboard pump to get a decent shower. I have to go find it.
One advantage to 32 (max) psi water source... you don't fill up your holding tanks very often.
You are lucky but your experience is as you said based on always going to the same place. What happens if they upgrade the water system when you're not there? My friend & I spent a full day repairing his Class C. Every fitting was leaking from not using a regulator. I'm not saying you need a regulator for your RVing needs. I use my seat belt all the time even though I hope I never need it.
Page of 5
