RV.Net Open Roads Forum: Tech Issues: Installing Vinyl Insert trim
 > Installing Vinyl Insert trim
elkhair
Huntington Beach, CA
Posted: 06/27/09 03:40pm Link  |  Print  |  Notify Moderator
The vinyl insert that covers screws in the track at front of my 5r kept coming out (the trailer is only 3 years old, but I guess the UV works on it) so I cut it off and ordered a roll of white 1" wide vinyl insert trim to replace it.
Of course, the ad for the trim says the usual," Easy to Install." I saw on one ad that you should "just pinch the vinyl trim in the middle & slide it into the track." I tried to do the pinch bit, but I didn't actually start at the very top of the trailer, I just wanted to replace the horizontal piece under the extended front of trailer, then back and down the vertical section. Doesn't happen.
Has anyone replaced this kind of trim? I'd sure appreciate your advice if you have. I will try the "slide it into the track" but am kind of doubtful.......
Thanks,
Bill
donn0128
Pronounced Ore-gun
Posted: 06/27/09 03:50pm Link  |  Print  |  Notify Moderator
Needs to be warmed, and try a small bit of lubricant, like soapy water. Generally unless the aluminum part is damaged it will snap in easily.
Don,Lorri,and Charlie Bear 2016
The Other Dallas
LarryJM
NoVa
Posted: 06/27/09 04:00pm Link  |  Print  |  Notify Moderator
I've replaced taken if off to seal the screws and never had to warm it or use any lubricant. I just slip one side in and pushing against the side that is in the other side will slip into the metal molding. I can reinstall a 10' section I would guess in less than 60 seconds.
I'm unclear what the exact issue the OP is having, but I never liked to try and piece sections together since I've had the top piece pop out of the metal molding. It's cheap enough to replace it in continuous sections. At the ends on some installations they like to fold it over and tuck the end under the metal molding. I don't like to disturb the metal molding if at all possible. When replacing at the roof top I like to put a big ball of butyl caulk about 1/2" from the end and push the insert vinyl onto the ball for one seal and then fill the cavity at the end with a good adhesive sealant.
Larry
RAINKAP INSTALL////ETERNABOND INSTALL
elkhair
Posted: 06/27/09 04:14pm Link  |  Print  |  Notify Moderator
Larry, I will agree that, with the vinyl trim that's been in the track for a year or more, you can remove & re-install it like you say. Have you done that with a NEW piece? I can't!
Bill
LarryJM
NoVa
Posted: 06/27/09 04:23pm Link  |  Print  |  Notify Moderator
Bill
YES, I had my last trailer for 26 years and had to replace that vinyl insert molding about every 10 years since it would harden and eventually crack. I carry a 25 or 50' roll of the new white in the trailer in case I need it. To get it started squeeze like a 6" section in both hands and get that 6" section in the metal molding and then while holding it in with one hand start feeding one side into the metal molding and once you have like 6 to 10 inches in take the other hand that was holding the initial 6" of trim in and start forcing the other edge into the opposite side of the molding and just continue doing that.
Larry
* This post was edited 06/27/09 04:58pm by LarryJM *
LarryJM
NoVa
Posted: 06/27/09 04:30pm Link  |  Print  |  Notify Moderator
Another thought and I have never done it with the vinyl molding but the directions to install the RainKap says to put one side in and then using a screen door rubber installer roll the opposite side into the other side of the metal molding. That RainKap is thick and that is the only way to insert it. You might give the rubber screen door roller for the vinyl insert molding if your having a problem installing it as I described.
Larry
Dutch_12078
Winters south, summers north
Posted: 06/27/09 04:47pm Link  |  Print  |  Notify Moderator
I've been installing the stuff for years just by setting one edge in the track and squeezing the other edge into place. Do not pull on the vinyl as you go, and leave it as loose as you can, especially going around corners. It will shrink over time, and if it's too tight, it will pull out of the track.
Dutch
2001 GBM Landau 34' Class A
Trailer Trash 2
Santa Fe Springs, CA
Posted: 06/27/09 05:08pm Link  |  Print  |  Notify Moderator
I got rid of the vinal and went with the rubber type, I dont know which will last longer, but if it last longer than 4 years I'll do rubber again.
Don & Georgia
AKA: Trailer Trash 2
Real trucks don't have spark plugs.
2009, Dodge, 3500, Q Cab, Cum/Diesel, D.R.W.
Pulling a Super Fine Montana 2980RL
LarryJM
NoVa
Posted: 06/27/09 05:43pm Link  |  Print  |  Notify Moderator
Just interested have a link to the rubber type ... hard to imagine something rubber would stay in that metal molding and with the UV issues vinyl can be made somewhat UV resistant, whereas rubber can't. Seems like rubber is a step down from the vinyl stuff so that's why I'm asking and I have never seen rubber insert molding. I must have 100' to 200' of pieces of used and new vinyl insert molding in a plastic grocery sack in the trailer right now. [emoticon] ... I just can't throw out stuff that might be needed, but probably never will [emoticon]
Larry
jberts
St. Louis, MO
Posted: 06/27/09 08:23pm Link  |  Print  |  Notify Moderator
I replaced the screw cover molding on my 92 Jayco. Must have used 175 feet worth. I thought there would be an easier way, but once I started getting the hang of inserting one side in the track, then squeezing the other part in it was a breeze. I also used the rubber, being it was easier to get into the track. Also made sure to caulk all exposed ends.
