RV.Net Open Roads Forum: Fifth-Wheels: Weights
 > Weights
Fifth-Wheels Related Tips
carrollti
Sumter, sc
Good Sam RV Club
Posted: 06/28/09 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
Need help finding the Pin Weight:
TV is a 2004 F250 SD 6.0 PSD Factory says 12500 towing capacity
5th Wheel is a 2008 Wildcat LSBS 33 ft.
Truck Weights
Front = 4800
Rear = 6084
GVW 8800
Cat scales:
Steer Axle = 4640
Drive Axle = 5940
Trailer Axle = 8340
Gross Weight = 18920
Truck and Camper loaded for a weeks vacation in Charleston, SC
Tim
Screamingeagle
Pennsylvania
Posted: 06/28/09 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
It looks like your truck weights are from the rating sticker on the truck. Those are the maximum ratings, not what the truck weighs. you need to weigh the truck on the scale without the trialer.
Screamingeagle
2008 F450 Lariat
2008 Big Sky 340RLQ
Drew and Judi and the boxer boys
hotrod4x5
Southern Calif
Good Sam RV Club
Posted: 06/28/09 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
Well, first of all, you are WAY over the GVWR for your truck. 10,580, or nearly 2,000 lbs over. No, you aren't quite over the axle's ratings, but whoever told you that you were good to go with that truck and 5er combo has no idea what they are talking about.
To find the pin weight, you need to now weigh your truck alone, with the same amount of "stuff" that was in in when you weighed the whole setup. You can usually get a free re-weigh if you do it at the same time.
Subtract the un-trailered weight from the trailered weight to get your pin.
Rodney 2005 Laredo 29GS 2002 F250 V-10 Hughesnet Satellite Internet
Screamingeagle
Pennsylvania
Posted: 06/28/09 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
He`s not over his tow rating.
hotrod4x5
Southern Calif
Good Sam RV Club
Posted: 06/28/09 09:33pm Link  |  Quote  |  Print  |  Notify Moderator
Does that make it ok to be nearly 2000 lbs over the GVWR of the truck? Not in my book.
souraider
Rogue Valley, OR
Posted: 06/28/09 10:02pm Link  |  Quote  |  Print  |  Notify Moderator
The pin weight of the fifth is killing ya. The problem with the pre '05 F250s were the rather low GVWR #8800. Not knowing the configuration of your truck, you probably do not have but #1300 to #1700 of cargo capacity (after wieght of truck and etc) I am certainly not one to say what you can or can't tow, but you may want to try and lighten up the pin weight.
06 Ford F-350 PSD CC FX4
06 Savoy 29RKS
JMTTS
52.1122 N, 106.5625 W
Good Sam RV Club
Posted: 06/28/09 10:11pm Link  |  Quote  |  Print  |  Notify Moderator
The following note is included more than once in the 2004 Ford Towing Guide
Trailer king pin weight should be 15-25% of total loaded trailer weight. Make sure vehicle payload (reduced by option weight) will accommodate trailer king pin weight and weight of passengers and
cargo added to the towing vehicle. Addition of trailer king pin weight, and weight of passengers and cargo cannot cause vehicle weights to exceed rear GAWR or GVWR. These ratings can be found on
the vehicle Safety Compliance Certification Label.
IMHO 2000# over GVWR is way too much
J & M
2005 Cardinal 33TS LX with TrailAir
2004 Chevrolet Silverado 3500 4x4 DRW D/A (LLY) Crew Cab
JIMNLIN
Big Cabin, OK
Posted: 06/29/09 05:33am Link  |  Quote  |  Print  |  Notify Moderator
as screamingeagle says without your trucks unladin rear axle weight were all guessing.
My guess would be most 2500 trucks rear unladin will weigh approx 2800 lbs. Your truck rear ladin weight is 5940 lbs which says your pin weight is approx 3140 lbs.
Actual pin weight is determined from axle and tire weight numbers loaded and empty.
Your truck is at max axle/tire capacities. Keep good tire on the rear axle.
"good judgment comes from experience, and a lot of that comes from bad judgment" Will Rogers
'03 2500 QC Dodge/Cummins HO 3.73 6 speed manual Jacobs Westach Linex
'97 Park Avanue 28' 5er with two slides 16" BFG Commercial LTs
Star Gazer
Nicholasville, Kentucky
Posted: 06/29/09 07:04am Link  |  Quote  |  Print  |  Notify Moderator
Back to the argument of which number to go by. You are way overloaded even though the axle can handle the weight. So what to do?
My 2000 PSD only has about 1600lbs cargo/pin weight capacity. That was figured by using a scale. Doesn't leave me many options for a 5'er to stay with in my GVWR. You are nearly 2000lbs over that.
Glad I bought such a "Heavy Duty" truck.
2000 F250 PSD 4x4
2005 Four Winds 18B (mobile observatory)
My Astronomy Pics
1990 Sea Ray 350 Sundancer
Chris
Shelter Bay, Wa
Posted: 06/29/09 07:31am Link  |  Quote  |  Print  |  Notify Moderator
Fat trucks rule!
My Rig
2001.5 2500 STD CAB AUTO SLT 4x4, CTD 4:10's, Bomb'd to Tow
2005 Cardinal 29WBLX.
 > Weights
