foghat
Calgary, Canada
Hi all,
Question about greasing axle bearings.
The axle on my 2 year old jayco tent trailer has grease nipple under the dust cap. Is it sufficient to just use a grease gun on the nipple? Or do I still need to take things apart and grease the bearings manually?
If I had to guess I have about 3,500km on it.
Thanks.
rightlaneonly
Sonora ca.
Personally I don't like using the zerk fittings on the axle. I believe, after many years repacking bearings on cars, trucks, and trailers that you need to clean and inspect bearings before repacking. Using those zerk fittings on the axle just pumps excessive grease into the cavity in the hub and doesn't do anything to clean out dirt, debrie and any metal that maybe in there from a bearing failure. More work but in the long run, IMHO, worth taking every thing apart and doingit manualy, which reminds me, both of mine are over due.
Leroy & Jane
2005 chevy 96 wildwood and now an Aliner sportliner.
I wanna go where I haven't been,
but still wanna see what I've seen again.
Vulcaneer
Northern New England
I guess it is OK on an axle that does not have brakes. But one really needs to repack wheel bearings every year. And if you do that you should not need to worry about the bearings at all between packings.
No way you should touch those zerks if you have brakes on the axle.
2006 F350 V10 4X4 SC SB SRW 4.30 22,500 GCWR
Keystone Sprinter 33'9" 12,500 GVWR
Pullrite Super Glide 18K
Super Duty, Super Cab, SuperGlide
foghat
Calgary, Canada
Yep, I've got brakes. I guess I'll take things apart tomorrow. I trust things should come apart the same way even with the zerk fitting?
Chuck&Gail
In the Colorado Mountains
I am again odd man out. When we had Dexter Ez-Lube axles, which sounds like what you have, I gave them a few SLOW pumps with a HAND (do not use air gun) grease gun before each major trip. I also took apart ONE wheel every other year to grease by hand and check brakes. Worked great for over 30,000 miles, then we traded "up" to a TT without that nice feature. Never got a drop of grease on brakes.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
2001tundra
Surry , NH
Hi, I did four wheel bearings a few weeks ago . I rested the grease gun on my leg , turned the wheel while I was pumping slowly. 35 minutes, get the correct grease of of Dexters web site
2001 Tundra TV , 18 ft Cikira Classic Cruiser
C Schomer
Buckeye, Az.
I replied in your spindle post before I saw this one. Craig
67Airstreamer
Louisiana
I use the zerk fittings on my Jayco. I wouldn't keep a trailer if I had to grease the bearings every year.
Bob/Olallawa
West of Seattle
67Airstreamer wrote: I use the zerk fittings on my Jayco. I wouldn't keep a trailer if I had to grease the bearings every year.
And I wouldn't tow a trailer that I didn't tear down and check the bearings and brakes every year or two.
07 Chevy 2500 4x4 gas
07 32ft Holiday Rambler TT
"A well regulated Militia being necessary to the security of a free State, the right of the people to keep and bear Arms shall not be infringed." -- Second Amendment, United States Constitution
red31
Bryan
Download a copy of the Dexter complete service manual.
Bearings/Hubs chapter begins page 45
Greasing ez-lube bearings is on page 54
