RV.Net Open Roads Forum: Travel Trailers: are these good ideas?
 > are these good ideas?
Travel Trailers Related Tips
jf504mp
Indiana
Posted: 07/02/09 11:07am Link  |  Quote  |  Print  |  Notify Moderator
I just put mud flaps on my TV. Took care of the rock and gravel issues.
redwake
Visalia, CA
Good Sam RV Club
Posted: 07/02/09 11:08am Link  |  Quote  |  Print  |  Notify Moderator
weathershak wrote:
I wonder if anyone decided to do away with their EDPM roof and linex the whole roof on the TT. In white of course.
wouldn't want to add that kind of weight up top... and it seems to me on the line of what the OP is asking unless the diamond plate is made of diamonds how do you figure diamond plate is more expensive than the linex material?
i haven't shopped but i would think diamond plate is cheaper.
TT: 08 Monterey 27 PT by Extreme RV
TV: 06 Sierra K1500 SLE Crew - 3.73:1 4x4 w/5.3L
Hitched with a Husky WD & SC.
Powered by Champion 3500
crab80
Virginia`s Eastern Shore
Posted: 07/02/09 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
I was thinking the same thing. The thin diamond plate they use on TT`s is not that expensive. Linex or other similar products is around $500 to do a truck bed, so I`m thinking 3 to 400 to do the lower front of the TT.
2010 Jayco 28BHS
2004 Chevy 1500 Ext.Cab 5.3L, 3.73, Bilsteins
Reese Dual Cam
Prodigy P3
Barker 3000 jack, 22 Blue tote
Fliposo
Colorado
Posted: 07/02/09 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
Herculiner DIY bedliner. A quart costs $40 +/- for grey, white, or red. From their website, Herculiner.com, it appears that you can roll it on. Auto parts stores stock or can get. I've seen off-road Jeeps that have their interior done in it for easy cleanup. Mask very carefully. It sticks to almost anything. With diamond plate you would have to cut to size/shape, fasten, then seal edges.
Retired April '09
100+ days on the road so far
'08 Dodge 1500 Quad with Hemi
'09 Jayco Jayflight G2 23FB
nny12972
NY
Posted: 07/02/09 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
I had my local boat-canvas guy make up a vinyl snap-on cover for the front of my TH (about 70% the frontal area of a TT)....no dings, no bugs, no cleaning....$65 including the SS snaps.
J
campin4kids
Indiana
Posted: 07/02/09 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
wow, nny12972, I'd like to see a picture of that.
crazyoldcoot
South of Arkansas
Posted: 07/02/09 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for your replies!
weathershak
Delaware
Posted: 07/03/09 06:46am Link  |  Quote  |  Print  |  Notify Moderator
X2
Don't like the view?? Then change it and Go CampingOur pics
CamperTech
Seacoast, NH
Posted: 07/03/09 08:04am Link  |  Quote  |  Print  |  Notify Moderator
I used spray-on bedliner on a small area of the keel on my boat. I beach it alot, so the aluminum was taking a beating there. Since the liner was sprayed on....no more scuffing the aluminum. It's great stuff.
You folks may want to rethink the "out of level" thing though. Absorbtion refrigerators can be damaged by operating out of level. Short term damage is minimul but, over a long period of time you could end up with a problem that is quite expensive to repair.
Most fridges have a 3deg front to back, and 6deg side to side tolerance level. Beyond that damage will start to occur where liquid pools at the low temp evaporator. If out of level, the liquid can't flow so it ends up burning the anti-corrosion products that are mixed with the coolant. (usualy sodium chromate) The stuff hardens and blocks the tubes causing failure of the cooling unit.
* This post was edited 07/03/09 08:20am by CamperTech *
Happy Campin'
W
Husker Jerry
O'Neill, Nebraska
Posted: 07/03/09 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
I had the lower 3 ft. or so of the front of my TT sprayed with Rhinoliner about 6 years ago. The result looks very professional, & if you didn't know better, you'd think it was installed at the factory. Its done a good job taking care of the rock chip problem. This was done at the suggestion of Jayco customer service.
2001 Ford Excursion V 10
2003 Jayco Designer 31FKS
Twin Honda Eu2000 gen sets
