RV.Net Open Roads Forum: Beginning RVing: HELP PLEASE! Inverter isn't working
 > HELP PLEASE! Inverter isn't working
Beginning RVing Related Tips
Takastone
Sunny Whittier California
Good Sam RV Club
Posted: 07/02/09 08:09am Link  |  Quote  |  Print  |  Notify Moderator
I'm in the mountains where our 2000 Wanderer Glide Slide is and somehow have weak internet...
We hooked up our electricity to the trailer (1am in the morning) and turned on a light. It was nice and bright then all of a sudden it went dim...All the 12 volt lights are dim and the fridge isn't working too. All the Plugs are working as well as the air conditioner and microwave.
I believe the culprit is the inverter? Not too sure of the name but the unit that changed the household current to 12 volt? It normally makes a little fan noise. It isn't now.
I checked the fuse box..o.k. checked the 15amp and the 30amp fuse and changed them all just in case...still it isn't working....
Is there any quick fix I can do?
Thanks...Irene
Takastone
Good Sam RV Club
Posted: 07/02/09 08:13am Link  |  Quote  |  Print  |  Notify Moderator
I APOLOGIZE...the batteries seem to be dead... the unit that checks the grey, black, fresh water and the battery is dead. I push the battery button and it quickly turns red and goes away....
Thanks...Irene
tvman44
Southwest Louisiana
Posted: 07/02/09 08:14am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like your converter is dead.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
CamperTech
Seacoast, NH
Posted: 07/02/09 08:16am Link  |  Quote  |  Print  |  Notify Moderator
Hi TAKASTONE.
Sorry to read about your troubles....
The appliance in question is actually a CONVERTER. 120vac to 12vdc.
Check your general purpose circuit breaker, if that is not tripped the converter has likely failed.
If you can't get to an rv service center, a quick way to get back "on line" is to hook a 12v battery charger up to your aux batteries. Let them charge for 1/2 hour, or so, before you start using systems. Leaving the charger in place should keep you going until you can get the converter repaired.
Good luck.
Happy Campin'
W
Cliford
Whidbey Island , Washington
Good Sam RV Club
On my camper did the same thing there was a fuse inside the converter.
do a search u should find more
2003 2500 Dodge CD
2000 Damon 27R Hornet
2005 Chev 1/2 ton Silverado
2007 Forest River Cherokee Lite 18DD TT
beemerphile1
I'm only 54, I'm not a
Good Sam RV Club
Posted: 07/02/09 08:25am Link  |  Quote  |  Print  |  Notify Moderator
Your converter is connected to 120 volt somewhere. Mine is plugged in with a regular electrical plug. Even though my converter is in an outside cabinet, if the GFCI in the bathroom trips, the converter and refrigerator will not work.
If not that. your converter probably has fuses in it.
p.s. when asking questions like this you should always give as much info as possible. IE. brand and type of RV, brand and model of converter, etc.
Tim (in NE Ohio)
"Okay, I admit it, the only thing I'm really good at is being me."
2006 Weekend Warrior FK1900 towed by 1998 Ford E150 4.6L
2009 Aliner Sport towed by 2009 Pontiac Vibe 1.8L
1996 BMW R1100GS
2007 Trek 7.2FX
2005 Trek Madone 9spd.
2oldman
Indio CA
Posted: 07/02/09 08:28am Link  |  Quote  |  Print  |  Notify Moderator
Even with a bad battery if your CONverter is working ok, should be fine. Good thing it wasn't 1am in the afternoon.
Takastone
Good Sam RV Club
Posted: 07/02/09 08:32am Link  |  Quote  |  Print  |  Notify Moderator
THANK-YOU! I hit the reset button on the GFCI and it works! Thank-you Thank-you!
and Thank you all for responding!
rene
beemerphile1
Good Sam RV Club
Posted: 07/02/09 08:38am Link  |  Quote  |  Print  |  Notify Moderator
You are welcome, where do I send the bill?
RCFlyer
Washougal, WA, USA
Posted: 07/02/09 08:46am Link  |  Quote  |  Print  |  Notify Moderator
Glad to hear your problem is solved! When you get home take a few minutes and go through your electrical system to understand where your converter is so you can check it to see if it has a fuse or fuses and figure out which circuit breaker serves it. OEM converters are a common failure point, so good to know as much about them as you can.
2005 F-350 SRW LB Black Harley Davdsn, 6.0 Pstroke w/auto, Excite liner, ARE "Z" cap w/Yakima rails & slide/tilt window, PIAA 1500 bu lights. B&W TO Ball hitch, Firestone bags
Wife: Stef the quilter
Dog: Chase, the Golden Retriever
3 sons, 8 grandkids
