RV.Net Open Roads Forum: Class A Motorhomes: Why Do MH Tires Blow Out...??
 > Why Do MH Tires Blow Out...??
Page of 5
Cloud Dancer
San Antonio and Livingston TX USA
Posted: 07/02/09 12:42pm Link  |  Quote  |  Print  |  Notify Moderator
fish doctor posted:
"highway patrol states that underinflation and or overloading are the main reason for tire failures in thier accident investagations. age of tires was not a determining factor"
On a good day, most of us would likely agree,...I know I would.
On an average day, most of us would say each case is different, and has its particular reasons (mostly never revealed).
And, I would say that the root of the problem is that the proper selection AND constant maintenance is not only costly, but it's A MAJOR BIG BOTHER (PITA).
For example, for me to perform the satisfactory purchase and the maintenance, I had to make it as convenient as possible to accurately check the air pressure (and to add air if necessary) I had to build my own totally portable compressor(140 psi capable). Plus, I had to acquire the other equipment/materials, including a digital gauge(accurate/expensive). All this, after special ordering a new MH making sure the factory weighed all four corners, and making sure the tire capacity was correct, and making sure I was the only one to drive on these tires.
Just to give you an idea of what I mean, here's some photos:
Willie & Betty Sue
Miko & Sparky
2003 41 ft Dutch Star Diesel Pusher/Spartan
Floorplan 4010
Blazer toad & Ranger bassboat
Cloud Dancer
Posted: 07/02/09 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
I check the tire air pressures prior to every time I hit the road (assuming the tires have had plenty of time to cool).
I keep track of the history/trend of lose of pressures. My tires will lose 1 to 2 lbs if the MH sits more than 15 days. If the pressure is even one lb low, I pull out the compressor, crank it up and AIR UP.
I keep my tires clean, and I vigorously apply 303 about every 6 weeks.
ETC, ETC
SunflyerA
Andover, Minnesota USA
Good Sam RV Club
Posted: 07/02/09 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
Of course the reason age is not a primary reason for blow outs might be because most people don't have tires that are too old......Studies must always be taken with a grain of salt...my tires lose 3-5 lbs of pressure when they sit for 8 months in winter storage.
sunflyer
2005 Fleetwood Excursion 39S
350 Cat
If you are what you eat; then I am fast, cheap and easy
Briteskys
Mesa, AZ
Posted: 07/02/09 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Willy,
Would you mind giving the model # of your Accutire gauge. I can't seem to find one online that looks like the one you have in the case.
Thanks very much.
'02 Beaver Patriot Thunder
Jeep Grand Cherokee
Ron & Jane's Travels
Cloud Dancer
Posted: 07/02/09 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
Briteskys wrote:
Hi Willy,
Thanks very much.
They introduced this unit around 2002, and the model is MS-4722 (the box sez item # 01-339-01).
mdennis
Lakeland,FL
Posted: 07/02/09 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
I finally switched to nitrogen and have not had a problem. The air does not leak and the tires stay cool. If you look at alot of the big rigs on the road you will see that they are running nitrogen as well.
Matt D.
Lakeland,FL
2008 Keystone Freedom Lite 279TB
2005 Ford F150 Supercrew
Reese Weight Distributing Hitch
Reese Dual Cam Sway Control
Nomadac
Columbus, IN
Posted: 07/02/09 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
And you carry a spare nitrogen tank to air up if the pressure is low? This may work for you but all of the reports I have read stated that race teams or airplanes are the only uses that offer an advantage. For cars or light trucks it is a profit center for tire stores and not worth the investment. Do a Search on this subject and you will find many discussions, etc.
Arnie
2003 Travel Supreme MH
38KSO1 Cummins ISC 350HP
Car Dolly w/1996 Toyota RAV4 2WD
1963 Pontiac Grand Prix
HobbyHauler
South of Nashville, TN
Posted: 07/02/09 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
Can you back that statement up?? It certainly is not true for all the fleet trucks serviced at one large OTR tire company here in Tennessee. This includes 4 major national trucking companies.
My experience tells me that less than 1% of the big trucks run pure nitrogen. Of course normal air is 78% nitrogen so I guess everyone uses it in their tires!
Les Stallings
2002 Monaco Dynasty Jack 38, ISL 400, TAG
Toad: 2003 Saturn LW300
Lug_Nut
Newmarket , Ontario, Canada
Posted: 07/02/09 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
Nitrogen does leak through the tire casing albeit at a much slower rate than plain air. This is due to the monicules being larger than that of oxygen. However, it does leak somewhat, therefore will need a top up now and again.
'07 Newmar Essex 45' ISM 500 4 slides
Dutch_12078
Great Sacandaga Lake, NY
Posted: 07/02/09 03:10pm Link  |  Quote  |  Print  |  Notify Moderator
I use a $10 digital gauge that reads within a pound of lab calibrated gauges, and a $45 12-volt compressor to manage my tire pressures. Works for me. I'm in no hurry...
Dutch
'95 Coachmen Catalina 322XL
F-53 chassis, 460 V8
Page of 5
