RV.Net Open Roads Forum: Truck Campers: Air Bags
 > Air Bags
mranger1911
Sitka, AK
Posted: 07/02/09 09:15pm Link  |  Quote  |  Print  |  Notify Moderator
So I'm finally getting air bags for my 07' F-350. Ive had air bags before on other trucks with out a TC and usually install the air supply vavles on the rear bumber, on either side of the license plate. But with my AF 990 it cover the rear bumber. So my question is: Where did you guys install your vavle so that you can adjust you air presure while the TC is on you truck?
Thanks
Matt
06 F-350 PSD crew cab w/ 07 AF 990
Eycom
Fl to NY
Posted: 07/02/09 09:23pm Link  |  Quote  |  Print  |  Notify Moderator
Mine are attached on the opposite corners under the rear bumper.
F-350 PSD
Lance 1121
Reddog1
El Dorado, CA
Posted: 07/02/09 09:31pm Link  |  Quote  |  Print  |  Notify Moderator
I mounted mine under the dash, on the left side of the steering wheel. I could sit in the seat, out of the rain and wind, and air the bags. I never get mud on the valves. Since my original install, I installed a cab controller. I "T"ed into my under dash air supply valves. I can use the under dash valves if my controller fails. I also mounted the controller in the cab, under the center console.
Wayne
fueling around
NW MN
Posted: 07/02/09 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
If you don't want one of the cab controller systems (I don't), then plumb them into the fuel door. Always on top for a long camper plus a mostly protected spot.
I have a short camper so the bumper mounting works well. I do have to reach under the overhang. A few quick strokes with the bicycle pump to adjust my pressure.
John
1997 Dodge 2500 CTD
1989 Cascade 8½ Self-contained Truck Camper
?? Eureka Timberline 4 tent
Raiders5
Morgan Hill, CA
Posted: 07/02/09 11:48pm Link  |  Quote  |  Print  |  Notify Moderator
I agree...mine are inside the fuel door sticking straight down from the top.
Raiders5
2005 F-350 PSD, Crew Cab, 2WD Dually, Lariat, Air Bags, Rancho 9000's w/in Cab Control
2005 Lance Max 1181 All Options
Arcticfox1
Nashville
Posted: 07/03/09 01:03am Link  |  Quote  |  Print  |  Notify Moderator
I would go with the incab controller. Then you can air up on the spot and air out when you get to the camping spot. AIr back up and not have to carry the camper 190 miles down the road to get to an air hose.
Good luck
AF1
Sturgeon-Phish
Ohio
Posted: 07/03/09 06:31am Link  |  Quote  |  Print  |  Notify Moderator
This is a very timly thread as I'm putting the bags on now. One side is in and I have not ran the plumbing. I will investigat the fuel door mount. I never would of thought of that! Thanks
Jim
2000 Citation Supreme 10'6"; 1996 GMC 2500 6.5 diesel, Kennedy Exhaust, Heath remote PMD, 97 Airbox, Amsoil Fluids, Michelin LTX's Rancho 5000, Tork Lifts, Extra leaf in rear, Firestone Air Bags, Boost, EGT, Trans Temp pillar pod
LEN Retired
SW Michigan ( Two Paws )
Good Sam RV Club
Posted: 07/03/09 07:01am Link  |  Quote  |  Print  |  Notify Moderator
I had the air bags installed yesterday and the business asked where I wanted the stems, I had no clue, so they said most of them they install are in the fuel door, I like this location, dont have to bend over or worry about the stem being hit with something, but I also like the in cab installation too!
06 GMC 2500HD Duramax, 2007 Holiday Rambler Alumascape Suite 32SKT,3 slide 5th wheel " SEMPER FIDELIS "
mattydmax
tucson
Posted: 07/03/09 07:11am Link  |  Quote  |  Print  |  Notify Moderator
I installed behind the fuel door also because my little 12v pump would still reach that area from the battery connection up front. It works well there and no crawling around the rear bumper under the edge of camper. Don't forget to keep the two sides seperate.
saggys
WI
Posted: 07/03/09 08:28am Link  |  Quote  |  Print  |  Notify Moderator
I have mine in the wheel wells, this setup uses only a short piece of hose for each side.
1999 F350 4WD CC SRW V-10, 4.30 Tow Package, HD Camper Package.
1999 Northstar TS1000, Torque Lift tie downs with Fastguns.
2006 Triton Frontier 17 with 60hp Merc 4 stroke tiller.
2003 Lance 1010.
 > Air Bags
