mranger1911
Sitka, AK
Anyone got pictures of the fuel door options. Just for a little reference on my part.
Thanks
Matt
06 F-350 PSD crew cab w/ 07 AF 990
Catch This
Ashburn VA
Good Sam RV Club
Becuase I didnt know any better, mine were installed are on either side of the rear license tag...what a mistake that turned out to be. I have to get down and slide under the camper to increase or decrease the pressure.
I was thinking about moving them to the side of the rear bumper to make them more accessible. The previously mentioned fuel door sounds even better. Someone please throw some pictures up for the rest of us to see.
'06 Lance 845 on '03 F250 4X4 used for surf fishing.
trvsdad1
peoria,az.
Good Sam RV Club
Do Not forget to get "stable loads". You won't need nearly the pressure in air bags with them installed.
TRVSDAD1
Sturgeon-Phish
Ohio
I just finished installing my air bags today and I used the filler door set up. The air valve for the drivers side is on the left upper say @ 11:00 and the passengers side is right upper say at 1:00. LEaves plenty of room for the fuel cap removal and fueling. Also it was drilling through plastic and not steel.
The notion of using the filler door was very timely for me.
Jim
2000 Citation Supreme 10'6"; 1996 GMC 2500 6.5 diesel, Kennedy Exhaust, Heath remote PMD, 97 Airbox, Amsoil Fluids, Michelin LTX's Rancho 5000, Tork Lifts, Extra leaf in rear, Firestone Air Bags, Boost, EGT, Trans Temp pillar pod
LEN Retired
SW Michigan ( Two Paws )
Good Sam RV Club
Same here for the 11 and 1 ,
06 GMC 2500HD Duramax, 2007 Holiday Rambler Alumascape Suite 32SKT,3 slide 5th wheel " SEMPER FIDELIS "
john126
Mid Hudson Valley
Matt, I too have the air valves located in the fuel filler compartment,in my '06 F350. Also have compressor mounted under the pickup body, with in cab controlls and guages. Have never had to use the manual air valves, so I can't tell you how convenient they are.(just looked like a good spot) Do like the in cab controlls though. This is the third truck I've had this set of air springs on.Dealers won't give me any allowance for them,(when I trade) so I clean them up repaint them and re-install them on the new truck. Best of luck with your install.
John
wsdepa
Raleigh, NC
Wheel wells - I like to be able to watch my air bag when I am filling it to get the bumpstops so that they just start to push on the overloads. Also it keeps the line short and simple.
2006 F-350 S/C 6.0 DRW 4x4 3.73, Airlift,Energy Suspension bump stops. 2005 Lance Max 981,Polar Cub a/c, both awnings, EU2000, Yakima box.
http://truckntravels.blogspot.com/
Get in shape America - walk, run, paddle or ride a bike!
zumdish
Vernon, NJ
mranger1911 wrote: Anyone got pictures of the fuel door options. Just for a little reference on my part.
Thanks
Matt
Sure.
2008 F350 FX4 V10 DRW, Air Bags & Stable Loads
2008 Bigfoot 25C10.6
JoeVita
Phoenix, AZ
trvsdad1 wrote: Do Not forget to get "stable loads". You won't need nearly the pressure in air bags with them installed.
Would Timbrens be considered a substiture for "Stable Loads"?
06 Ford F-350 Crew Cab SB DRW 4x2 Diesel Automatic,Class V hitch
05 Lance Max 881, Happijac Tiedowns, Struts,
Circle J two horse, slant load Horse Trailer
One Appendix Quarter Horse Gelding Dun Color
Lots of Stuff
WA. USA
saggys wrote: I have mine in the wheel wells, this setup uses only a short piece of hose for each side.
Ditto and they are right near the tires so very convenient when checking air pressures.
DG
03 Chevy Silverado Regular Cab 2500HD 4X4 Duramax
04 Lance Lite 915
