JFJ
TN
My 05 Raptor 3612 DS is having a fuel stattion issue. When I flip the on switch on to turn on the gas pump it will not turn on. Has anyone ever had this problem before. Once I had to replace a fuse, and that solved the problem, but this time the fuse is not bad.
2007 Dodge Megacab 2500 4X4 SRW
6.7 Cummins w/6 Speed Auto
2005 Raptor 3612ds
Pacbrake Air Bags
Prodigy Brake Controller
Pullrite Superglide 24K
Y-Guy
Tri-Cities, WA
Good Sam RV Club
JFJ I assume you already checked the cut off switch? Our 05 3612 had one setup on the battery, removed the knob to kill the power to the fuel pump. Do you have anything like this?
Winnebago Sightseer 35J | Custom ATV Trailer | Polaris Sportsmans & Honda Recons
sac16263
Placerville, CA
Check the fuse. opps sorry saw that. Is it the type you turn the knob on that has a timer? I've seen those go bad.
2004.5 GMC Sierra Crew Cab 2500HD Duramax/Allison, Carbon Metallic LLY 6" RCD lift, 315/75/16 Toyo Mt's on 16x8 eagle 102's. Airbags, Prodigy P3, Edge Juice with Attitute, Intake and Magnaflow Exhaust
2009 Weekend Warrior LE3305, 16K Superglide Hitch
mapguy
Puget Sound
If you have power to main switch for fuel pump -I would make sure you have power before and after the timer next. If you have power here - next power check is at the pump...
Idahoan
Layton, Utah
My trailer has two switches. It has the timer inside, then another switch outside by the fueling station. The switch that is located outside is not an outdoor/sealed type. So it gets wet and corrodes a little from time to time. Sometimes I have to mess with it and reseat the leads on the back of it to get power to pump. One of these days I will change it with a better sealed switch.
2005 Dodge Ram Quad Cab CTD
2009 Eclipse Attitude 23LFS
2008 Yamaha Grizzly 450
2008 Yamaha Raptor 250
1992 Honda CR125R
2003 Yamaha TT-R125LE
2008 Yamaha TT-R50E
2006 Kawasaki KFX 50
JFJ
TN
The only switch I know a/b is the one on the pump...actually a small lever that you flip and then the pump starts running. I don't know anything a/b a timer or a separate switch at the battery compartment. I do see where the wiring goes to the battery and has a fuse on it. I have had to replace this once before, but this time the fuse is not bad. I did recently go to a 6 volt battery setup (two) from a 12 volt setup. Could I have messed something up here?
chipworkz
California
JFJ wrote: I did recently go to a 6 volt battery setup (two) from a 12 volt setup. Could I have messed something up here?
Since the 6 volt batteries are connected in series, you should NOT have any trailer wires connected to either battery in middle. (The positive and negative that connects the batteries together.)
Beyond that everything else would work the same way.
2002 GMC 2500HD ext cab LB SRW 8.1 Allison P3 controller Reese 20K air lift bags Rancho 9000's
2009 MVP Tahoe 395 TIB
08 KFX 450R
07 TRX 400 EX
07 TRX 250EX
92 KX 250
Custom Sandrail
River&Sand
San Diego, CA USA!!!
If it is a Greco (PBL) pump, it could be the gears, your trailer is in the age group. It will usually blow the fuse, but I have seen it when is doesn't. Even had the key (plastic) break on the drive gear on a buddies. Couldn't hear the pump running until you crawled under the trailer and put your ear near it.
River&Sand
05 Chev Ext.Cab K3500, Dmax/Alli, DRW, Reese Signature 18k, Jordan 2020
06 Weekend Warrior LE3305, 5th Airborne, Dexter E-Z Flex
01 HighJumper SandSprite 3 Dune Buggy
HavaRaptor
Lake Havasu City
Good Sam RV Club
What River&Sand said. I had this happen on my Raptor when it was brand new. They came out with a different type of gear. Problem solved!!
2009 Cyclone 3950
2000 Kenworth T2K
2008 Ford F250 4X4 Diesel
2009 Polaris Ranger
2008 Can Am Outlander 650
2009 Can Am Outlander 800R
