RV.Net Open Roads Forum: Travel Trailers: how level is level ?
 > how level is level ?
700mb80min
Everywhere
Posted: 07/03/09 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
Hiya , how level should my TT and truck be compared to each other when looking from afar ? This is after they are hooked of course . Mine has a slight " v " position but only to the tune of a few inches . is this acceptable ?
2000 Prowler Fleetwood Ultra-Lite
2000 Chev S10 4.3
BIKERK9
Santa Cruz, CA
Good Sam RV Club
Posted: 07/03/09 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
The tow bar should be level (not almost) when secured to the
truck hitch ball. This can be achieved by using a hitch insert that has the proper
rise or drop.
Tongue weight can be adjusted with a weight distribution hitch and or
adjusting the load in the trailer.
DoggyDaddy
2008 Damon Outlaw 37', WH-24, 8.1 GMC
Class A Toy Hauler
DoggyDaddy CommunityProfile
Terryallan
NC
Good Sam RV Club
Posted: 07/03/09 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
It would not be acceptable to me. But you are different. I like mine level. It towes better that way. A slight V suggests that there is too much weight on the back, and the front is rising. Taking weight off the front axle, and could cause sway.
Terry & Shay
Pioneer 23T6
04 F150, 5.4, Lariat SuperCab
Lazy Campers
NC
Chuck&Gail
In the Colorado Mountains
Posted: 07/03/09 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
I like the TT to be within 1" difference measured on FRAME, front to back, with front lower if unlevel. Mines 1/2" lower in front.
I like TV to be same angle unloaded and loaded, just closer to ground front and back. I measure how much wheel wells drop, and adjust WD hitch to get equal drop. Slightly more drop in rear is ok, mines within 1/8".
If TV is not level unloaded, it should not be level loaded, IMO.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
Shogun
Winnipeg
Posted: 07/03/09 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
Just be aware of your gross axel weight ratings.
If your tow vehicle sits equally lower front and back the the wdh then you may be overloading the front axel.
I found this out on a recent weigh in. I was 20 lbs over on the front axel.
I let a link out of the chains and the rear squatted a little more than the front and the weights were back under the max axel ratings.
Actually handled a little better with more weight in the back....
Spree 245ks. 2005 4Runner Limited V8. Blue Ox WD hitch.
Ron Gratz
full time RVer
Posted: 07/03/09 11:12pm Link  |  Quote  |  Print  |  Notify Moderator
Shogun wrote:
---If your tow vehicle sits equally lower front and back the the wdh then you may be overloading the front axel.---
I agree with Shogun. You should not try to get equal drop front and rear.
Both GM and Ford recommend that the WD system should be adjusted to bring the front of the TV back to approximately the height/load which existed before the TT was attached.
This means there will be very little load change on the TV's front axle and very little rise or drop. About 70-80% of the tongue weight will be carried on the rear axle and about 20-30% will be transferred to the TT axles.
Ron
Ron Gratz
full time RVer
Posted: 07/04/09 08:54am Link  |  Quote  |  Print  |  Notify Moderator
As to how level should the truck be when loaded -- you should check your Owner's Manual to see if it contains any specification.
For example, the Ford truck manuals I've looked at, beginning with the 1998 model year, contain a specification such as:
3. Measure the height of a reference point on the front and rear bumpers at the center of the vehicle.
4. Attach the trailer to the vehicle and adjust the hitch equalizers so that the front bumper height is within 0–13 mm (0.5 in) of the reference point. After proper adjustment, the rear bumper should be no higher than in Step 3.
The instructions do not indicate any preference for having the front below or above the reference height -- as long as it is within 1/2".
Also, the instructions do not say the TV should be "level" -- only that the rear, with TT attached and WD applied, should not be higher than when the TT is not attached. The weight distribution recommendations for GMC vehicles are similar.
Relative to the unhitched loads, the front axle load might have relatively little change and the rear axle load might increase by 75% of the tongue weight . Depending on the stiffness of the rear springs, the rear might "squat" (relative to the unhitched height) by about 1-2" with WD applied.
Ron
wrenchbender
Phx
Posted: 07/04/09 10:14am Link  |  Quote  |  Print  |  Notify Moderator
The more axles the more level.
NCHornet1
Mt. Airy, NC.
Good Sam RV Club
Posted: 07/04/09 11:48am Link  |  Quote  |  Print  |  Notify Moderator
You really aren't looking for level as you are parallel to the ground. Nose down slightly in the front is okay, never nose up!! As for the TV, the rear will always drop more than the front, but you want to shift some of that weight to the front axle. When I am hooked up I drop 3/4" on the rear and just shy of 1/2" on the front and my TT is perfectly parallel to the ground and it tows very stable.
NCH
2000 Ford F350 4X4 PSD,CC, DRW
4:10's, BTM Muffler, Isspro Gauges,
Coolant Filter,CCV Mod
FTVB , Ford AIS
6.0 Cooler,SCT2 W/DP's 40 tow & 80 econo,Zoodad mod
2005 Keystone Hornet 30BHSS
Reese Dual Cam
Family of 4 saved by Grace!!!
MY TRUCK
OUR TRAILER
uptime
Deltaville, VA, USA
Posted: 07/04/09 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
NCH
Good advice. We often use the term "level" but in fact we should be looking at the rig being parallel to the road. Since most roads & parking lots are not level that means all measurements should be from established points at each corner of the TV. I suggest that you put a piece of masking tape at each corner of the TV and establish an unhooked position. Make a zero mark on the tape (suggest something like 35") measured from the road/parking lot. It's usually good to push the front down about 1/4" to 1/2" and about 3/4" for the rear. This assures that all four wheels of the TV is carrying part of the load of the trailer. The front of the trailer should be in a straight line with the TV or maybe 1/2" lower.
2004 Dodge Ram 2500 Diesel, quad-cab, short-bed, tonneau cover
2005 Jayco 23'Baja, dual axle, Equalizer hitch (1000# bars), Prodigy brake controller
