RV.Net Open Roads Forum: Fifth-Wheels: Question for SuperGlide Owners
 > Question for SuperGlide Owners
Fifth-Wheels Related Tips
RoryTek
Phelan, Ca
Posted: 07/03/09 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
Have you ever had to tow a trailer with your SG without the capture plate for a very short distance?
The reason I ask this is because a friend of ours here at the campground asked me to move their fiver since some bone head almost backed their trailer almost in to their front door and wanted to move to another spot since her husband had the TV away from the campground.
I was only going to move it no more than 100ft with no 90 degree turns.
Thanks
Rory N6OIL
08' Chevy Silverado 2500 Duramax LMM ClubCab, PullRite SuperGlide
08' Cougar 289BHS
RVN'S 4 US
On the Road
Posted: 07/03/09 03:07pm Link  |  Quote  |  Print  |  Notify Moderator
No. I do know that you want to keep anyone with a standard hitch away from yours unless a special accessory sold by Pullrite is used. That is addressed in the manual. The dealership I purchased from did not have the accessory and had to wait until I moved the unit to have access to that part of their service area again.
I think I have read here that you can move a standard kingpin 5er for a short distance with the only problem being that it would not activate the slide feature. But, I do not want to give that advice. The manual may address that question also if you check there. My manual is with the 5er.
Plan for tomorrow. Live for today. Learn from yesterday.
RoryTek
Phelan, Ca
Posted: 07/03/09 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah I did read the manual and it said it may or will cause damage due to free fall or nothing to stop the hitch from slamming back. I was looking to see if anyone has tried it.
"Can I pull other 5th wheel trailers with my SuperGlide hitch?
Your SuperGlide hitch can only pull trailers equipped with the SuperGlide trailer plate. If you hook up to a trailer that does not have a trailer plate installed, there is nothing keeping the hitch in the forward towing position and the weight of the trailer will cause the head to turn and slam or “free fall” to the rear which can cause damage to the hitch and the king pin. We do not recommend locking the hitch in any way to keep it in the forward position.
fordsooperdooty
Orange Kounty Kalifornia
Posted: 07/03/09 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
PullRites are expensive, for that reason alone I wouldn't take the risk. Quote from PullRite-"Your SuperGlide hitch can only pull trailers equipped with the SuperGlide trailer plate."
There are posts here on rare occassions, that guys have done so and wedged wood blocks into the slide first. Abusing a PullRite like that should be a crime!
This is our 7th new Jayco in 30 years! Loved 'em all!
smkettner
Good Sam RV Club
Posted: 07/03/09 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
You will need to lock the cam arm assembly from rotating.
Glenn Adams
Heading down the road without end and now I'm lost
Good Sam RV Club
Posted: 07/03/09 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
I would never risk damaging my Superglide muchless putting myself in an expensive liability situation should something happen to the other 5er. Surely you are not the only TV in the CG set up to pull 5th wheels.
Glenn and Lorraine, FullTimers
Member- Montana Owners Club
2005 GMC Sierra 2500HD 4x4 Extended Cab Short Bed Duramax/Allison
PullRite 16K SuperGlide hitch
2007 Montana 3485SA 38' 5th Wheel
ford truck guy
Pennsylvania
Posted: 07/03/09 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
DO NOT DO IT !!!!!!!!!!! If you have a universal capture plate that will fit, bolt it up and than move it.Why throw away $2,000.00 ??.. Joe
Joe and Lori
2009 Ford F350 SD 6.4
08 Montego Bay
Hers are my pictures
C.B.
APPLETON WI USA
Posted: 07/04/09 12:48am Link  |  Quote  |  Print  |  Notify Moderator
If you had one of these you could.
Without absolutley not.
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE~EQUA-FLEX~
PRODIGY CONTROLLER~C-BETR MIRRORS~ROTOCHOKS
CB Family Fleet
Butch&Barb 03Cardinal~Duane&Holli 05CedarCreek~Kris&Katy 06Cherokee~ Brian&Maia 04Jayco
RoryTek
Phelan, Ca
Posted: 07/04/09 10:05am Link  |  Quote  |  Print  |  Notify Moderator
Hey C.B. I take it that is not a factory part, but hey it gives me an idea. Dumb question does Pullrite approve of your mod?
C.B.
APPLETON WI USA
Posted: 07/04/09 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
I sent drawings,pictures and offered to send an extra one I have to PullRites head engineer.
He said no need he could make his own off the pictures and drawings I sent to him.
The thing that impressed him the most is I did not modify their product in any way.
PullRite will not manufacture and offer this slide stop adaptor for sale due to product liability issues.
For the same reason I do not make and sell them.
* This post was edited 07/04/09 02:30pm by C.B. *
