chiefward
Covington, GA
What type of splitter do i need to operate two separate receivers from the same cable? I purchased one from HD that was suspose to be for satellite\digital signal but does not work with my two receivers.
2000 Fleetwood Terry, Model 275J EX
2003 Ford F250,V10,6.8L, Super Duty, 4WD, Quad Cab
16K Reese Hitch w/slider
Johno02
Lexington, TN USA
Good Sam RV Club
Unless someone disputes me, it is one antenna, one receiver ONLY!! The receiver talks to the LNB on the dish, with a little voltage and a switching signal. Two receivers on the same dish does NOT work. However, there are dishes with two pickups, each of which can be wired to different receivers. If I have stated this incorrectly, soeone please correct me.
Noel
Noel and Betty Johnson
'99 Hurricane 2007 HHR 1 wife, 2 1/2 dogs
chiefward
Covington, GA
Noel. What you say makes since. I'll just have to run two cables like i'm doing right now. I have one of the splitters that has two lbn inputs with four TV outputs.
hershey
Albuquerque,(fulltime) NM, USA
I'm pretty sure you have to have a dual LNB to run two receivers and two coaxial cords. Once cord wont work.
hershey - albuquerque, nm
Someday Finally Got Here
NASCAR 14 - 99 - 5
hwybnb
chiefward wrote: Noel. What you say makes since. I'll just have to run two cables like i'm doing right now. I have one of the splitters that has two lbn inputs with four TV outputs. I am guessing here but based on what you said I think that what you have is a multiswitch, not a splitter. You cannot have a splitter in the cable between the satellite dish and the receiver, and one dish (one LNB) can run only one receiver.
In order for your multiswitch (if that is what you have) to run two or more TV receivers with independent program selection you will need two inputs; i.e. you will need two LNBs. If your dish has two of them you can connect them to the multiswitch and operate up to four TV receivers.
Kart-Racer
Long Beach, CA
you need a Multiswitch
jim87vette
Arizona
Hmm I wonder whats on my house I have three Recvers..and I dont recall a multiswitch.Im just as curious as the rest on this one?
08 GMC 3500 Dually Duramax
96 Chevy 2500 6.5
05 Yamaha Rhino
04 Gearbox 335FS 5er 14k wet
hwybnb
jim87vette wrote: Hmm I wonder whats on my house I have three Recvers..and I dont recall a multiswitch. Im just as curious as the rest on this one? Some of the newer multi-LNB dishes have a built-in multiswitch, so it is hard to tell.
chiefward
Covington, GA
hwybnb. Your are right I have a multiswitch. It is attached to the two cables coming out of my portable dish with a single LBN and I can run four cables from it. I see the logic of having a cable to each receiver and therefor each TV.
hwybnb
chiefward wrote: hwybnb. Your are right I have a multiswitch. It is attached to the two cables coming out of my portable dish with a single LBN and I can run four cables from it. I see the logic of having a cable to each receiver and therefor each TV. Thanks for the feedback. Just for completeness, if your dish has two cables coming out it is not a "single LNB". The terms get confusing but you have a single housing with two LNBs in it.
