June Cannon
Nicholasville KY
Good Sam RV Club
cannot find the cb cable in my 2007 Fleetwood Revolution LE. Unit has cb antenna mounted on roof and is supposed to be cb ready.
old guy
Oregon (pronounced Or e gun)
good question, but without bing there and looking I have no answer for you.
Deen
Vancouver, WA
On our DSDP it was coiled up and tied way up under the dash. Luckily I did find it by lifting the dash panel where some of my fuses are located. Still haven't found the dedicated wires for it though. They are supposed to go directly to the battery to eliminate electrical noise but I don't know. Since I very rarely use the CB it's not a big thing.
J-Rooster
Port Orchard, Wa. U.S.A.
Good Sam RV Club
Frank, I have a Winnebago and mine was wrapped up under the dashboard. Good Luck on your search! Rooster
jerseyjim
New Jersey
Good Sam RV Club
If you bought new, you might contact your dealer of purchase. If you bought used, and STILL cannot find it, contact any Winnebago dealer that handles your model. Go in person and have your info (model, serial #, etc.) in hand. Someone can probably look it up.
YC 1
Yuba City Calif.
CB ready does not always mean there is a cb antenna. Sometimes it only means they have power set up under the dash. I found this in a Winnebago. Sometimes the rubber ducky antennas on the roof are for the dash radio and there might be another if you have an outside entertainment center. If you actually have a cb antenna you might find that taking the dash guages out will give you access. All depends on the MH of course. I can take my dash panel loose in about two minutes with an electric drill. I found my cb cable rolled and nylon tied.
H/R Endeavor 2008
2007 Hummer H3 toad
Ranger Boat
Mandolin Guy
West Central Georgia
old guy wrote: good question, but without bing there and looking I have no answer for you.
Gee, thanks for that reply. It helped a lot.
David
Light travels faster than sound. That's why some people seem bright until you hear them speak.
Retired Cop, 31 years
Jack M.
Calgary, Alberta, Canada
Good Sam RV Club
June, lift the dash cover, to the right of the back up monitor, held in place by one torx screw. It will be toward the front right above your subwoofer. You could also reach in from under the dash, in the centre behind the speaker grill. It is there.
Jack & Nim Myton
'10 American Allegiance, 42T,
`08 CR-V, `RVPUSHR`
President & Moderator, FMA 'Fans of Revolution' Chapter, Good Sam, FMCA
www.revolutionmotorhome@yahoogroups.com American Coach Association
June Cannon
Nicholasville KY
Good Sam RV Club
Thanks to Jack of Alberta Canada, I located the cb antenna cable. I should have also asked if there is an electrical pigtail already wired for cb radio. Is there one?
Thanks for your help.
Jack M.
Good Sam RV Club
Nope. I didn't find any pigtail or wire connection for the c.b. However I wired it into the power source to the dash radio. The dash radio is switched so that power to the c.b. and the dash radio can be on with the ignition off. Good luck.
