RV.Net Open Roads Forum: Class C Motorhomes: I got my Class C!!!!!
 > I got my Class C!!!!!
Class C Motorhomes Related Tips
Jabba2009
road
Posted: 07/04/09 12:47am Link  |  Quote  |  Print  |  Notify Moderator
Been searching for a while and found on this morning on craigslist.
1999 29FT JAYCO CLASS C MOTORHOME 18K MILES ((MUST SEE))ROOF AIR DASH AIR GEN.AWNING SLEEPS 6 REAR QWEEN BED EVERYTHING WORKS RUN'S AND DRIVE'S GREAT VERY CLEAN TO MUCH TO LIST.ASKING $16900 OBO
Well I made it out there first everything looked good and the guy sold it to me for 16k! feels like a new rv!
After I got it home I looked it over, only found 2 issues
-electric step not working as expected, there's a little 2 wire piece at the bottom of the door that seems to be misfunctioning, sometimes it works sometimes it doesn't.
-the roof in the front by the cab front has cracks, looks like they tried to fix. So I'll have to seal it, rv came out of Nevada in last 2 months so not too worried ...but in Washington this will have to be fixed by the end of summer.
has anyone had issues with their electric step sensor, or have any advice on how best to seal the cracks?
Also if there's a recommended list of stuff to have in your RV or a greatest hits of northwest RVing I'm all ears!
Thanks
Sean
Gale Hawkins
Murray, KY
Posted: 07/04/09 01:02am Link  |  Quote  |  Print  |  Notify Moderator
Welcome Sean. Sounds like you got a great girl there. User her locally every chance you can get like watching a fire works show tomorrow night, go shopping ou out to eat, etc. The minor issues will work to the surface and so you can work through them. Do you have any service records?
Admiral
Upstate Ohio
Posted: 07/04/09 04:06am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like a nice unit. The step should be an easy fix. Sometimes the screen door gets out of alignment or the sensor isn't positioned correctly and can't sense the magnet that activates it. Try moving it closer or align it to see if it' helps.
Class C overhead bunk areas are notorious for seams leaking and rotting the structure; usually from lack of maintenance. Before you just fix a crack in the roof do some probing around the interior and under the bed area and see if there's moisture present.
Either way, an inspection of the exterior roof should be first on the agenda. Look for missing or cracked caulk along the seams remove it and reseal whatever needs it. A search on the C forum should give you more specifics on what you're facing.
Good luck and have fun.
2004 Damon Daybreak 2960F V-10
05 Honda Element LX
Practice safe dining....use condiments.
radardog
delaware
Posted: 07/04/09 06:53am Link  |  Quote  |  Print  |  Notify Moderator
Seal over the cracks with Eternabond roofing tape. A accepted permenant repair.
I am sure others here have used it to seal leaks.
The fan always wins
Kamphiker
South Florida (this 'aint paradise anymore)
Posted: 07/04/09 07:25am Link  |  Quote  |  Print  |  Notify Moderator
Congrats ! Welcome to the club.
EternaBond tape on the roof seams that can not be seen. I would f1rst clean seams, then use a caulk like Proflex RV and then EternaBond tape.
Look at his post How to Reseal Good information and if you follow resealing looks like it came from the factory (or even better!)
2006 Winnebago Outlook WF324V
2009 Honda CR-V 2wd TOAD ......Campgrounds in the Smoky Mountains NP
Last Camping trip ->Elkmont Summer 2009 slide show
NEW-> Memories of OLD Miami, Fla. (pictures)
Hook&Go
San Antonio, Texas
Good Sam RV Club
Posted: 07/05/09 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
check Kwikee Stepsfor a solution on your steps. It will give troubleshooting and bench checking solutions. You might just have your steps jammed. Try lubricating all of the moving parts of your steps.
Joe & Debbie Speer
USAF Retired
2006 Winnebago Outlook WF332G
2001 Chevrolet Tracker (TOAD)
Jabba2009
road
Posted: 07/05/09 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the help played around with the step for an hour, I think its a short in the sensor. when i squeeze the door sensor it will engage. for now I've switched the step off (at the panel with the light switches,etc) just so it doesn't chop someone at the knees.
If I put a normal inline switch in the place of the magnetic one could I just use that? truth be told the whole automatic magnet thing seems a bit much (remind me of this when i accidentally rip it off in motion...)
I picked up 4 tubes of roof leak repair at walmart, was in the rv section (red tube, can't remember the name)Put it over the cab cracks up front. other than it being black it looks good. Main concern was if it rains later this week I need to be sure I'm sealed (Seattle...) . still planning to get the roof professionally checked, but figure this is a great sanity test.
Thanks
Sean
burlmart
Baton Rouge
Posted: 07/05/09 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
Jabba2009 wrote:
... played around with the step for an hour, I think its a short in the sensor. when i squeeze the door sensor it will engage. for now I've switched the step off (at the panel with the light switches,etc) just so it doesn't chop someone at the knees.
Welcome, and THANKS FOR BEING THE FIRST TO CONFIRM I WAS NOT CRAZY and that the sensor can get a short - likely due to dust.
For instance...and we never hear what actually worked.
It just occurred to me you should squirt it THOROUGHLY w/ CRC electrical cleaner spray, and I bet she is fixed...I will do that to mine.
(I've been sounding off this for a long time w/ NO confirmations.
* This post was edited 07/05/09 05:03pm by burlmart *
2005 Trail Lite 213 B-Plus w/ 6.0 Chevy
