RV.Net Open Roads Forum: Tech Issues: HELP trying to go away and can't
 > HELP trying to go away and can't
Page of 6
thomas malenich
sound beach, new york 11789
Posted: 07/04/09 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
I am suppossed to leave tomorrow, and I still can't figure out my socket trouble. I have the signals and tail/markers. I cannot find a wire that is hot all the time nor can I find one that is hot when I step on the brakes. I only have two wires (a black and white) to work with. I think I found that pair which looks like it attaches to the brake controller (a drawtite). The controlller does not light up at any time.
Thomas and Laura Malenich
1988 Suburban 1500, 4WD
Scotty 16 1/2' , smaller and loving it
2 kids and 3 dogs
bldrbuck
Boulder, Colorado
Good Sam RV Club
Posted: 07/04/09 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
This may help.The 7 Pole RV Electrical Plug
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 90 Nomad 28' 5er, 375 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 4 Trogan T105 Batteries, Spare tire and wheel and folding ladder. Me, wife and 2 spoiled Maltise furkids.
thomas malenich
Posted: 07/04/09 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
That doesn't help - I already know the positions. I made some progress. I found the brake wire on the tow vehicle. It was the white wire. When I step on the brakes, the brake lights come on, so I assume the brakes are working. I still do not have 12 volt power - I guess the only problem not having 12v is the breakaway, right, as the TT battery is dead................
enblethen
Moses Lake, WA USA
Good Sam RV Club
Posted: 07/04/09 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
Just because the brake lights comes on doesn't mean the brakes are working.
Look around the brake controller for an in line fuse.
Follow the wires to the engine compartment. There should be some device to provide power to the trailer to charge. It could be a relay or an isolator. Hopefully there is a fuse or circuit breaker. This could be blown or is not auto resetting circuit breaker.
The black wire maybe the charge wire.
Bud
Suzuki XL7 pushing Pace Arrow
thomas malenich
Posted: 07/04/09 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
This can't get much worse. My right turn signal is not working. Both the left and rights blink very dimly when I turn on the right. The tow vehicle relay is also not clicking at a steady rate - it acts like there is a short. Guess I am stuck home.
GWolfe
Kansas
Posted: 07/04/09 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
This sounds like you are not getting a good ground between truck and trailer.
Flagstaff 617SD 1991
Comet Camper 1963
thomas malenich
Posted: 07/04/09 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
Just went out to check that. Ground seems ok at the ends of both connectors - 7:00 at the tow end and joining at the mating tt side.
stevesandidge
kingsport tn
Posted: 07/04/09 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
a quick check of the brakes is hold a compass next to each wheel, below the bearing cap. when the brakes are activated, the compass needle will swing towards the wheel. the next best way is a clampon amp meter on each hot wire going to each individual brake. obviously the compass is a lil faster, but the clampon is the final check.
steve
steve sandidge
RVIA certified rv tech
camping world rv university
class 54
fix-it rv service
USMC 1982-1994
91 holiday rambler imperial 37'
K&R
Oklahoma
Posted: 07/04/09 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like a ground problem to me also.
Try hooking a wire or jumper cables from truck to trailer.
thomas malenich
Posted: 07/04/09 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
Why would I need this if I have a good ground through the sockets???
Page of 6
