RV.Net Open Roads Forum: Tech Issues: Broken awning?
 > Broken awning?
Tech Issues Related Tips
ulvik
Angie, Louisiana
Posted: 07/05/09 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
When I pull out my main awning it only unrolls about 75% of the way, then you cant even get it to roll out the rest of the way using force. But when rolling it back up it goes back up with no problems.What could it be? It unrolls normaly but when it gets so far it just flatly refuses to go the rest of the way.
2005 2500hd crewcab 6.0 4.11
2005 Palimino Puma 282rkss
Angie, Louisiana
BrickBrain
Pearl River, La
Posted: 07/05/09 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
Don't know if I have an answer but I do have a question or 2.
When unrolling, does it just stop or does it feel like the spring is tightening?
Does it always stop at the same spot?
Was it working correctly in the past and this just started?
How long is the awning?
My nieghbor had the same issue with a used RV he purchased. We took it apart and found someone had change one spring but the just shoved the old parts into the tube instead of removing them. This got caught up in the works when he would unroll it.
'03 Allegro 32BA on Workhorse W20
'06 Saturn Vue
Demco Aluminator
RM 9700 Brake
ulvik
Angie, Louisiana
Posted: 07/05/09 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
Yes the awning always stops in the same place. and yes it just stops and cant be unrolled any more, It has done it the last two times we have went camping. And the awning is about 20ft. Any ideas?
* This post was edited 07/05/09 05:30pm by ulvik *
Dreamscape
Abilene Texas
Posted: 07/05/09 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
What brand is it, just curious? I just installed a 20' Zip Dee and want to understand why you are having problems.
ulvik
Angie, Louisiana
Posted: 07/05/09 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
The awning was made by A&E Systems by Domitec
BarneyS
S.E. Lower Michigan
Good Sam RV Club
Posted: 07/05/09 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
Are you remembering to loosen the knobs on the backside of the awning arms before you pull it out? This will cause that symptom you are describing if they are not loose.
Barney
2004 Sunnybrook 30FKS TT
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Check out the RV.net Blogs!
Visit our website here
ulvik
Angie, Louisiana
Posted: 07/06/09 06:51am Link  |  Quote  |  Print  |  Notify Moderator
I checked it again to insure that the knobs were loose when I put the awning down and they are. Any other ideas?
jmanatee
Willington, CT
Good Sam RV Club
Posted: 07/06/09 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
If the knobs are loose.... and there is nothing else you can see restricting the awning,... There is only one thing left that I can think of, The spring.
Maybe it is adjusted too tight see here http://www.rverscorner.com/RV_Awning_Repair.html for possible retention and or replacement of the awning spring
Jon
Our RV Web Site | Our New RV
Our Solar Install | Roof Replacement Project
Twenty years from now you'll be more disappointed by the things you
didn't do than by things you did. Explore, Dream, Discover. Mark Twain
2008 Monaco Cayman XL 38PBD
 > Broken awning?
