snowolf
buchanan, michigan
well it finally happened. i have a broken front window on my old "real-lite" camper. was traveling to Cedar Point in Ohio and a hawk flew up from the road and hit the grill of my truck and hit the window on the camper. Its not broken but has a large star crack. I know i will never find a replacement. . Its NOT a show camper just a beater for weekends snowmobiling,atv,nascar and amusement parks.
wondering what to do to save it?
~DJ~
Boise, Idaho
Good Sam RV Club
I am not aware of what you are looking at. Obviously not a flat piece of glass. Maybe if you posted a pic someone could give you some good ideas.
Capt PJ completely eliminated the front window on one of his campers!!!
2010 F150 Super Cab XLT 5.4 4X4 Short Box
1988 Nortstar 8' pop up TC
Honda 2000
26th Marines RVN 69-70 Semper Fi
M-14 was the only Woodstock I saw in 1969.
SoCalDesertRider
SanDiego, CA, USA
Is it just flat glass? Go to a glass shop and have them cut you a new pane to fit the opening.
Or, if you don't like the window, go to the metal yard and have them shear you a piece of 16 ga galvanized sheet to fit the opening and put that in instead of a pane of glass.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
snowolf
buchanan, michigan
well its not a flat window. its plastic and protrudes 1" or so. its tinted. Ive actually thought about covering both window(holes) with some diamond plate.....
http://photos-h.ak.fbcdn.net/hphotos-ak-........6946_100000024841835_51303_2464684_n.jpg
SoCalDesertRider
SanDiego, CA, USA
Are the edges flat? If it's just a bubble window with flat edges, you can replace it with something flat. Tread plate aluminum would be a good choice too.
SoCalDesertRider
SanDiego, CA, USA
In your pic it appears that replacing with something flat shouldn't be a problem.
snowolf
buchanan, michigan
what about somekind of Lexan or something glued to the inside of it?
~DJ~
Boise, Idaho
Good Sam RV Club
Looks like a glass shop could easily replace the windows with flat glass. Probably the least expensive option too.
kcabpilot
CA
I don't know if it's a law but isn't that front window safety glass? Back in the old days kids used to ride up there and look out it but probably no one does that anymore. I don't think the blind on the front window of our Lance has been opened in the past 10 years. That's probably why new units don't even have the window - less expense and weight for something that serves no purpose.
Our first camper was an old King of the Road and, believe it or not, that front window actually swung open.
1994 Lance 990 on 1997 F350 PSD Dually "Rhino Haunches"
We also have a 'truck' that FLYS
Our recent camping trips
pjay9
Tacoma, WA
If you take the old plastic one out a good plastic shope can make you another one! Or just go flat like others have said. Is the camper fibergalss sided or aluminum or ? There is a thread some place on what I did. Capt PJWhat I did!
2005 Lance 1161 2004 Dodge CTD 3500 Dually 2009 Raider 185 Pro Fish 90hp Yamaha
