RV.Net Open Roads Forum: Class C Motorhomes: Roof leak A/C
 > Roof leak A/C
Class C Motorhomes Related Tips
T.W.Hersey
Citrus Heights,Ca.
Good Sam RV Club
Posted: 07/16/09 11:19am Link  |  Quote  |  Print  |  Notify Moderator
Hi! I have a Fleetwood Jamboree 2007 when the wind is blowing I get a leak around the A/C, Striaght down rain no leak went to C/W for sealer they advise replace the seal has any one done this, how much of a job is this? What about the electrical and drain is there a problem disconnecting? Thanks for your imput.
fordsooperdooty
Orange Kounty Kalifornia
Posted: 07/16/09 11:25am Link  |  Quote  |  Print  |  Notify Moderator
Actually it may only need to have the bolts snugged down. The foam gasket that seals the a/c to the roof is held firmly pressed down by 4 bolts accessed thru the ceiling filter housing. Remove the screws securing the cover and snug (not too tight) the 4 bolts. That should do it, but after a few years the gasket may still have to be replaced, an easy proceedure!
A Jayco is not just an RV, it's a way of life!
T.W.Hersey
Citrus Heights,Ca.
Good Sam RV Club
Posted: 07/16/09 11:36am Link  |  Quote  |  Print  |  Notify Moderator
Good idea think I'll try snugging bolts first, Thanks
Fiverwheel
Southern CA
Posted: 07/16/09 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
That idea worked on my rig as well. Simple fix when road vibration and wear loosen the foam gasket!
2002 26.5 MB Lazy Daze
bgie
MA
Good Sam RV Club
Posted: 07/16/09 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
Snugging bolts and screws is always a good idea in a condo that goes down the road at 60+mph. When I think of all the vibration our coaches sustain, I routinely check bolts and screws and I am always surprised to find more places to look. I just found the bolts on both of my AC units very loose. I hope that is the source of your leak because it is an easy fix. I have reached a point where when I find something loose I apply a dab of glue (usually super glue gel, or goop) and tighten it down and then feel secure in it's security. I have found that if I want to loosen it for any reason the super glue bond is easily breakable.
Good Luck, Bill
Bill and Karen
Chloe, the Golden Retriever
2006 Jayco Seneca HG33SS
fisher60
Plant City, Florida
Good Sam RV Club
Posted: 07/16/09 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
I would not think the seal is gone on a 2007.
'01 Dutchman Express 28A, Master Tow, '06 Tuscon, '05 Honda VTX 1300
Good Sam Life Member
Roadfrog
Chilliwack, BC Canada
Posted: 07/16/09 09:38pm Link  |  Quote  |  Print  |  Notify Moderator
"fisher60" said it. Unlikely that the gasket needs replacing in an '07. The bolt tightening will do the trick. Tighten each one a little at a time, but not TOO much.
Cheers
Chris
1999 Winnebago Itasca Spirit 29N
1988 Campion Allante 195
 > Roof leak A/C
