randy&shereen
Jackson, MI
Hundreds of doors at some of the surplus stores. Take good measurements and see if they have a assembly that will work for you. It might cost less to replace than repair.
Randy
2004 GMC Sierra 2500HD SLT CREW CAB LONG BOX
8.1 Big block Gas/Allison 4:10 4x4
2004 Newmar Kountry Star 34 BLWB 3 Slides
jimw606
Morehead, Ky.
Good Sam RV Club
Have a look here for a door. Jim
http://www.rvdoctorgeorge.com/parts.html
jjtx22
Baldwin, Florida
Did the same thing to mine! I bought a plastic wall protector used on houses to prevent door knobs from going through walls! Matches the exterior pretty good. Looks factory! May be good to install one before it happens, just in case!
2003 Challenger 34TLB
2007 Ford F350 4X4
Carjoy
Talladega,Al.
My brother knock a whole in his door and was able to just by the outer skin on the door.Cost him around a $100.00 dollars doing the work himself.
schrecker96
NC
Did it twice! The toddler flung the door open and a nice hole was in the center of our door. If you have a friend that does body work they can fix it right up. Or Check with a dentwizard type place. We were lucky to have someone with the skills to fix it. We finally bought a door stopper so it won't open as wide. In the meantime a piece of duct tape makes a nice band-aid.
2004 Keystone Sprinter 293FWLS
2004 Duramax 2500 Crew
yoopercamper
Upper Michigan
jjtx22.....did you just put that over your door? I was thinking of a door knob bumper in white to put over it. Filled the crack with some caulking but of course it just doesn't look nice. UGH.
country46157
indiana
Good Sam RV Club
dependng on the color of door just shoot hole full of silicone. If you want to get fancy go to fiberglass and epoxy.
Rmcgrath53
Howell
Just fixed my door in the back I have a rear door that is a half size that flung open while traveling. I had a bike on the rear ladder. The door flew open and put 3 holes and three dents in the outer fibberglass skin. I taped the decals and bondoed the holes and dents. Then
I emailed the factory and they sent me the paint formula. I found a guy at church that has a paint store and he got me the paint for 60.00. Then
I primeed it The paint store guy then found me a guy to spray it ,and then he sprayed a clear coat on it. It now looks brand new, you cant tell it was evan done.
Ron
2009 sundance 2997bhs
2002 F350 4x4 7.3 diesel crew cab dually. 135,000 miles extra leafs.
Banks stinger/ with an edge attitude set at tow
prodigy 3p curt 20k hitch
trail air suspension trail air pinbox
2 e2000 honda w parralel kit
j2catfish
Newport, NC, U.S.of.A.
White duct tape!
K3500; Teton Homes 5er;
Native Texan - Transplanted Tar Heel
Retired USMC
Semper Fi !
jjtx22
Baldwin, Florida
yoopercamper wrote: jjtx22.....did you just put that over your door? I was thinking of a door knob bumper in white to put over it. Filled the crack with some caulking but of course it just doesn't look nice. UGH.
Well I cleaned the wound with some denatured alcohol first, then I covered the hole in the door with white duct tape then pressed the wall protector on the door. I don't even notice it anymore.
