RV.Net Open Roads Forum: Travel Trailers: Adjust chain type WDH
 > Adjust chain type WDH
Travel Trailers Related Tips
mrradio
Jamestown, ND
Posted: 07/21/09 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
I got a chain and bar type WDH/sway system with my previous HTT, which had a tounge weight of about 440 lbs. I was told by the service tech who installed it that leaving 3 open links and putting the fouth on the bar was about right.
I now have a light TT with a tounge weight of about 330 lbs or so.
The unit feels like it is tugging a bit...I'm guessing I maybe want to shift a bit more weight onto the hitch?
But I'm not clear if this is done by increasing the loose links before tension is applied, or decreasing the number of links.
Suggestions appreciated, thanks
hainsg...odne byg a ebbout riso
i
roel1223
Rochester Hills, Michigan, U.S.A.
Posted: 07/22/09 07:17am Link  |  Quote  |  Print  |  Notify Moderator
To increase the weight on the tongue you would leave less open links on the chain. I.E., go from 3 to 2 and see if that helps.
Ronald L. Roelant
eric james
Sioux Falls, South Dakota
Posted: 07/22/09 07:46am Link  |  Quote  |  Print  |  Notify Moderator
When ever you change trailers or tow vehicles, you should completely go through the set up steps for a weight distribution hitch.
Lots of step by step instructions and videos here: weight distribution hitch set up sticky
2009 Keystone Passport UL 290BH
2003 Ford Expedition EB 5.4L/3.73
mrradio
Jamestown, ND
Posted: 07/22/09 08:11am Link  |  Quote  |  Print  |  Notify Moderator
Great article
The dealer of the used TT did set up the shank and system so the units are very level when hooked up, but he didn't clarify what link might be most suitable to use on the chain.
The dealer of the former HTT specifically indicated, use the 4'th link.
Tv is a 2004 Yukon XL.
eric james
Posted: 07/22/09 08:16am Link  |  Quote  |  Print  |  Notify Moderator
Typically with less weight, you'd need less links under load, 100 pounds really isn't much difference. You're probably good with the way it was with the previous trailer.
mrradio
Jamestown, ND
Posted: 07/23/09 08:39am Link  |  Quote  |  Print  |  Notify Moderator
You know, this is so stupid but I thought I should clarify...
when you say "losing a link" adds to tounge weight; are we talking about from the "loose" end of the chain, or the end attached to the bar?
I was assuming we were counting from the loose end. IE, go from 3 loose to 2 loose at that end would add to tounge weight.
Thanks!
hotmod
Good Sam RV Club
Posted: 07/23/09 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
My son worked in an RV dealer for many years & he told me the best way of finding the proper setting was to first set the hitch height on the tow vehicle to match the height of the trailers hitch with the trailer level( on level ground measure to the bottom of the hitch on the trailer & set the ball height on the tow vehicle appx. 2" higher which would set them level at no tounge pressure)Park the loaded truck & trailer on level ground & change the chains one link at a time untill you get the trailer to just level or slightly below.
Butch, Winnie and the boss ms.Suzi
2007 Weekender 2002 Chev. 1/2 ton ext. cab short bed
Recently retired & just starting to enjoy the RV life
